Fastlane Install says Airspy lib not supported. Update dll
JamesWest
JamesWest
...and again, I'll ask that you give a screengrab of the directory showing the path, file names, dates and sizes - all are significant
...plus the deatils of the batch files and the appropriate config files - again all are significant
It would probably also help if you showed a screengrab of the DSDPlus path etc that was working for years. Is it still?
Also, you talk about FMP24 as well as FMPA - do you have an rtl device and an Airspy plugged in?
thanks for you help. i am working on this now.
JamesWest
Why are you running it in powershell?
I just tried it in as a shell command and it popped open and then instantly closes. no output of any type. does your copy of DSDPlus.exe in your Fastlane folder open when you just click on it?
a417
I just dragged a working copy of DSD+ FL to a new folder. If you double click it (or run it from a shell) it tells you first it can't find the following
  1. lame_enc.dll
  2. DSDPlus.frequencies
  3. DSDPlus.groups
  4. DSDPlus.networks
  5. DSDPlus.sites
  6. DSDPlus.radios
  7. DSDPlus.siteLoader
  8. DSDPlus.p25data
I copied one at a time into same new folder, program now opens, creates a .event & .bin file, and then asks if you want to update.
I think there's something going on under the hood of your system that's preventing normal operation, not necessarily DSD FL+ issues.
I did not copy the FL files over the freeware version.
cg
Connecticut
What version of DSDPlus FL are you trying to run? Some of this sounds like a version mismatch. Post the versions of those two programs that you have.
Way back at the beginning, you said you couldn't get get FMPA running, then said that you did. Do you see signals in that window?
Post the contents of the two batch files you are using, FMPA & DSDPlus
