FCC License question
birdieboy
I really wasn't sure where this belongs but since it involves Motorola equipment I put the topic here.
Does the FCC care which radios are being used on a business license as long as the number or portables is not being exceeded? My employer knows that I am a radio buff and has asked if I wouldn't mind using my personal radio at work when we are slammed which I do not have an issue with as long as it is legal.
Thanks,
Tom
cabletech
Puget Sound
As long as you are using a valid commerical radio within the correct band and are working under a valid license, then no, you will have no problem using your own equipment
nd5y
Wichita Falls, TX
The FCC only cares about the licensed power output, emission mode, number of transmitters, location and that all transmitters are certified for Part 90 (or whatever part the license is for).
birdieboy
Thank you very much for your answer, yes everything is programmed exactly to the license requirements. I have a CP200XLS and my employer uses CLS1410 radios.
