Feed Line Question
blueclawsink
Toms River NJ
Planning on purchasing an AirSpy HF+. I have antenna picked out but antenna has PL 259 connector. Anyone know where I can get 50 feet of feed line with the required SMA male connector to plug into the AirSpy HF+?
gutter89
Williamstown ny
I would use RG 8x with 2 pl259 or 1 pl and 1 "N" connector. then use a jumper with a n or pl female to sma
c_snyder
Amazon has a listing for 50 feet of RG8X for $31.98 with PL259 connectors on each end. You could get that and then get a short 3 foot RG316 jumper for both stress relief on the HF+ and a conversion to sma male.
50 Feet RG8X
3 Foot SO239 to sma male jumper
If you don't quite need 3 feet on the jumper you could wind the excess around a ferrite core for HF noise reduction if needed.
I'd strongly recommend not try to connect RG-8 or LMR-400 directly to those type of small radios. It'll put a lot of stress on the SMA connectors.
Common industry practice is to use a smaller jumper to make the final connection between the heavier coax and the device.
A short jumper of RG-58 and the connectors will work just fine and will not have a noticeable amount of loss. It'll take the stress of the SMA connectors.
Custom made cables:
https://www.theantennafarm.com/cata...e-assemblies-344/rg-8-lmr-400-9913-cable-395/
Get the SO-239/female UHF connector on one end to match your antenna, and put a female UHF or N connector on the other.
Then just get yourself a male UHF or male N to male SMA jumper made out of RG-58 or similar cable to make the transition.
