feed setup
DJBio
PEI
I just got a newer computer and a different scanner for the feed. A Realistic Pro-2037 and the computer has Windows 11 Home.
Input is set to the audio input with the sound set at about 75%. I went to the Broadcastify feed where I know there are test calls for local fire departments and not picking up anything.
I'm still trying to learn the in and outs of Windows 11.
DJBio
PEI
I just got in a new bcd996p2 was was setting it up on another computer to provide p25,digital truck channels etc and had everything set up and no audio on feed so i decided to disconnect from new computer and hook it up to the other computer i had my old feed from and in the streaming software i changed the feed information and still no audio so i sent information to broadcastify about it
DJBio
PEI
I have a new uniden BCD996p2 with the 1/8 audio cable plugged into the record plug on the back going to a adapter converted to usb with RadioFeed program and it’s connected to broadcastify but there is no audio feed on broadcastify site
DJBio
PEI
I am using Proscan Radio Feed and I did not know there was a setting for the record
Had it on a windows 10 and a windows 11
RMason
Mississippi / Colorado
Please check the recording settings on the 996p2. The 996p2 has settings to control what channels send audio to the record jack:
See: Easier to Read BCD996P2/XT Digital Scanner Manual
Set Record enables the REC jack for all channels or marked channels in the system or off.
Scroll to 'Set Record' and press E/●.
Scroll to one of 3 settings and press E/● to save and exit.
All Channel - The scanner sends the audio for all channels in the system to the REC jack, regardless of the channel’s record option setting.
Marked Channel - The scanner only sends the audio for channels that have the record option turned on to the REC jack.
Off - The scanner does not send any audio from any channel in the system to the REC jack, even if the record option is turned on for a channel.
DJBio
PEI
I was able to get it fixed up but now the volume is extremely low and I did go in and turn on the AGC to on
But in my windows settings I am unable to find where to adjust the volume settings
scanbc780
Usually Lurking
Maricopa/Yavapai Counties, Arizona
In ProScan Radio Feed, you should be able to adjust the volume with the audio control sliders under the Source Client tab.
There should also be a windows mixer button under that tab that will open the Windows sound control panel, and your settings should be under the recording tab. Select your input, select properties and click the levels tab. If no mixer button, look for your sound control panel in Windows.
DJBio
PEI
I tryed to adjust the audio for my feed but when I try it on the website the audio is low
My set up is usb to 3.5mm cable to my bcd996p2 with the cable into the record plug on the back of the radio
DJBio
PEI
For some reason I still can’t get the audio to work properly on this scanner and feed
I have the cable from the record port to the audio input on the computer
