Fire alert on G5 pager not audible while in amplified charger
aretterer91
I have a G5 pager that I was issued by my fire department. It is programmed to alert for EMS tone outs, and for fire tone outs. The two alerts are different from each other. I purchased an amplified charger to use with my G5. At first, everything worked as it should. The problem now is, when the G5 is seated in the amp, and a call comes through, I hear the two-tone through the amp, but when the pager goes into its “alert” phase, it goes completely silent. At the end of the “alert” phase, the voice portion of the transmission is audible through the amp like normal.
When the G5 is off the amp, it operates and alerts normally, as it should.
Could this be a flaw with the amp?
hazrat8990
Wyoming
Do you by chance have relay control enabled? Check the setting for TG List, and Sub Group List in tab E2 to see if one, or both are set up that way. The only thing I can think of is that instead of playing an audible alert, it's trying to send a signal to open a garage door, turn on lights, etc...
aretterer91
yes, I have enabled the relay control in the PPS software. It worked once before, when I first got the amp, but then all of a sudden stopped.
aretterer91
When an alert comes through, the alert light on the charger flashes, so i know it recognizes the relay activation, there’s just no sound.
hazrat8990
Wyoming
Do you actually have it hooked up to something? If not, you should probably turn off all instances of relay control. Just for grins, double check alert settings in E11.
aretterer91
I have a strobe and bed vibrator connected to it. It started acting up before I connected those devices though. The light and vibrator also work normally.
