Anytone First look Anytone BT-01 Bluetooth Microphone
ve2ri
Banned
Roxboro, Quebec
Anytone BT-01 Mobile Bluetooth Speaker Mic for AT-D578UV Models with Bluetooth
The Bluetooth mobile speaker mic acts like a wireless remote mount, giving you full control and functionality of your mobile radio in the palm of your hand. With a large 2.2 inch display, the Bluetooth mic has a larger display than the AT-D578UV series mobile. Built in front fire speaker for clear audio. Up to 30ft of Bluetooth range
ve2ri
Banned
Roxboro, Quebec
This is an Anytone Product for their radios only...
It may be possible, in the future, that others may offer similar technology.
R8000
Very Low Battery
I like the idea. I wish other mfg's would get the hint.
W6VVM
The YouTube videos I’ve seen make it look very sluggish at controlling the radio. I see that it’s possible to wire it, but I’m unclear on whether that just powers the mic or switches away from Bluetooth altogether. Would be great if it could be wired and offer a more responsive UX.
pcunite
This is a very cool idea. I want to mount my radio as close to an antenna as possible, and then totally remote control it. Was looking at FlexRadio. They run over your PC, but having a handheld would be great too. Wonder what the Bluetooth range is?
n1chu
Farmington, Connecticut
12-15 HOURS
I’ve been using the BT-01 since it first came out. While the battery life of the BT-01 seems sufficient, it’s a known fact a recharge will be necessary eventually so it probably should go without saying but keep the charge cord handy. My only wish pertains to where the charging port is located… on the side of the mic. I wish it was on the bottom instead. Because the mic does allow recharging while in use and the cord gets in the way. But it’s a minor inconvenience and doubtful that Anytone would relocate the charging port to the bottom of the mic so it acts like a corded mic while charging. Maybe an aftermarket mod will be explored in the future…
n1chu
I’ve only observed 3 minor inconveniences I’ve noticed with my BT-01. The charging port location which I commented on already is one. Another is the Bluetooth range could be a bit better. My experience shows a range of about 15-20 feet max and 10-15 feet reliable. The third item relates to the extensive menu, and the abbreviations used due to limited space on the display. While most all of my questions can be answered with the manual, there are some I still don’t understand. A cheat sheet or run card explaining them would be a nice addition, especially when traveling. Sure, I could pull over and consult the manual but even then, consulting a cheat sheet is faster. (I’ve started compiling one but it’s not all-inclusive as even the manual leaves me guessing what is meant.)
Navigating the menu can be a problem in some cases also… while searching for how to route the audio-to which speaker you want, you need to got to “Bluetooth” instead of “Settings”. I learned this by trial and error when I didn’t have the manual handy. Not complaining mind you, just looking at quicker ways to “learn” the radio and BT-01 mic.
