Florida Forest Service
lwvmobile
DSD-FME
Lafayette County, FL
do you still have the audio? Just wondering because ufile is asking me to pay for it to listen to the audio.
Unfortunately, I don't. I recently upgraded my remaining HDDs to SDDs and was being selective about what to copy and paste over to preserve. I didn't hang on to the audio for that. It really wasn't anything special anyways, just early morning radio checks on analog, and some aircraft reporting visibility conditions on P25p1.
Hi,
Looking for any of the frequencies or TGs (if on a TRS) that the Florida Division Of Forestry (DOF) uses to communicate with agencies.. maybe on the SLERS system. They just keyed up on Lee County's TRS with callsign "Calloosahatchee-2" (UID 8750002) in reference to grabbing dozers, with callsigns C68 and C62.
I read a thread a few days ago about some sort of mixed system across the state, but do they have regional communications channels? Seems unusual to think that a majority of operations are done via cellphone or via handful of VHF channels.
Johnathan
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
For us in Miami-Dade County and Broward County, we talk to Forestry on these Channels.
Using older handhelds considering nothing else for us is VHF Hi.
Can't speak for the rest of the state.
154.265 DOF "RED"
154.280 DOF "WHITE"
154.295 DOF "BLUE"
Try here its on the Florida Main Page at the bottom. Then find State Agencies and scroll down to Florida Forest Service .
Is this really it? How is this even practical for the entirety of DOF? I would think that the VHF is super spotty in all the brush across the state. (no disrespect intended)
902
Downsouthsomewhere
radioman2008
Batlabs user Wazzzzzzzzup (2001-Present)
800 System 1632 Tampa Bay Florida
on a good day, with my base scanners and antennas up 35 feet, ill get recordings of multiple areas of Florida DOF using the same frequency, separated by different PL tones. some DOF is now running P25, but its not that common yet from reviewing my recordings.
JimD56
that seems like a good list.
i had a good one on an old computer and don't see it anymore even with google.
Correct. Now a Second Source.
16 154.265 Mutual Aid - "Red Channel"
17 154.280 Mutual Aid - "White Channel"
18 154.295 Mutual Aid - "Blue Channel"
What do the colors mean? I know down here in Lee, we have some VHF channels that are also the same colors as those - do you think they might be DOF? I don't know the use of the channels.
JimD56
When we are dispatched with DOF our dispatcher will just say "DOF is on Red" blue, etc. Can't speak to anything else.
radioman2008
Addl info, further down the page.....
154.265 is VFIRE22
154.280 is VFIRE21
154.295 is VFIRE23
Echo4Thirty
Colorado Springs, CO
Texas does this too by reusing VFIRE21 as TXFIRE1 and VFIRE22 as TXFIRE2, but they use different PLs from the NIFOG standard.
902
Downsouthsomewhere
Nothing. They were randomly selected before the NPSTC standard naming convention of interoperability channels. They just picked colors to disambiguate the different frequencies. Seems to be a patriotic-minded person who initially dreamed it up. That's fine.
VHF is not very common in much of Florida, but, for the most part, agencies should transition to the APCO/NPSTC 1.104.2-2017 standard that the NIFOG follows for all mutual aid frequencies so the same kind of confusion that's in this thread doesn't propagate down to the field at an actual incident.
While the "Florida Forest Service" (there is no such thing as "Department of Forestry" anymore, it was renamed in 2011 under Agriculture and Consumer Services Commissioner Adam Putnam) uses these three frequencies (VFIRE21, VFIRE22, VFIRE23), they do not "own" the frequencies in any way, nor are they the exclusive end-user. When radios were programmed in narrowband mode, they should have been reprogrammed with the receivers in carrier squelch, but the transmit CTCSS in 156.7 Hz. Most of the equipment seems to have both the standard name and a reference to the old legacy name (either the full color name or R/W/B) to the right of the current channel mnemonic.
bravo14
Polk County FL
I was near Daytona today and got 151.340 Tac 10 Nac 065 (not sure if only certain regions or statewide). TG 10205
jeff
St. Augustine, FL
That's the input to the Region 10 159.45 repeater, NAC 065 is used in Volusia County. NAC 064 is the output for the region.
