basicallyimjoey
- Joined
- May 1, 2023
- Messages
- 1
I’m having the issue where my SWR will not stay rock solid. If I get it just perfect, it does. Any other time it’ll start to climb excessively, then hold steady. Or it keeps increasing. The PA cuts power & I’m forced to power off. Equipment is a Motorola MTR 2000 with the hated Notch Reject “flat pack” duplexer. Jensai I believe. 6 cavity duplexer. The SWR reading will behave different after tuning the notches with a VNA. I had it solid at 1.36SWR, so I know its possible. Moved the duplexer to a more permanent location, got paranoid & I’ve been chasing a good SWR ever since. Heres a screenshot of Motorolas software during transmit. It’ll start at 1.X, then gradually increase as the station transmits. Highest it goes now is 2.8 before bounce around between 2.6-2.8. A brief 30sec pause in transmit will put it back down around 1.8-2.0, then it starts climbing again. Brand new jumpers, Feed line is routed neatly, not corroded or pinched. Connection is waterproofed with thin coat of dielectric grease around outer threads only! Temflex top to bottom, electrical tape around that for UV protection. I can’t find the cause for a good, but rising SWR anywhere. Any input anyone has would be tremendous! Thank you!
