FMPx link error in Fast Lane - no audio
hiker679
Hi everybody
Just bought Fast Lane DSDPlus, so installed by putting files in proper places. Changed the input to 2 and output to 1 to match directions in this video. Changed output on SDR++ to match. Opened SDR#, Ran DSDPlus.exe -rp with admin rights and got this message:
FMPx link error = -5
(goal now just to hear audio)
What would be a good plan of attack?
Full output:
_____________________________________________________________________________________________________________________________
C:\DSDPlus>dsdplus -rp
DSD+ 2.465
Current working directory is "C:\DSDPlus"
Program role is passive digital decoder
Appending synthesized audio to file 'DSDPlus.wav'
Assuming FMPA/FMPP/FMP24 is signal source; auto polarity detect is disabled
audio output device #1 = '2 - ED270R M (2- AMD High Defin'
audio output device #2 = 'CABLE Input (VB-Audio Virtual C'
audio output device #1 (2 - ED270R M (2- AMD High Defin) initialized
Testing Base Files:
File: FMP24.exe PASS
File: FMPA.exe PASS
File: FMPP.exe PASS
File: FMP-Map.exe PASS
File: LRRP.exe PASS
File: Survey.exe PASS
File: airspy.dll PASS
File: lame_enc.dll PASS
File: libfftw3f-3.dll PASS
File: libusb-1.0.dll PASS
File: msvcr90.dll PASS
File: msvcr100.dll PASS
File: msvcrt.dll PASS
File: pthreadVCE2.dll PASS
File: rtlsdr.dll PASS
File: rtlsdr_FC0012.dll PASS
File: rtlsdr_V4.dll PASS
File: sdrplay_api.dll PASS
18 files checked
18 files passed
Base files test: All files passed
P25 data loaded; 0 networks, 0 sites, 0 channels
0 frequency records loaded
0 radio records loaded
0 group records loaded
0 site records loaded
0 network records loaded
0 site loader records loaded
Fusion decoding enabled
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 and Phase 2 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
Mono audio decoding initiated...
Initiating FMPx link using link ID 20001...
[Server is not listening on selected link ID]
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Why didn't you run it just as it was intended, when you installed it. FMP*-CC.bat and 1R.bat, without modifying anything, and get that working. Then move on to crippling it by using SDR#.
Use the menu system in DSDPlus. And go to CTRL --> Passive Digital Monitor.
And in SDR#, uncheck "Filter Audio"
dave3825
Suffolk County NY
Why not skip SDR++ and virtual cables all together?
How your looking to scan? Listen to random conventional digital signals, or listen to trunked systems?
slicerwizard
Toronto, Ontario
Using DSD+ with external signal sources
DSD+ can be used with external signal sources such as a properly discriminator-tapped receiver
or SDR software such as SDR#. To use DSD+ with these sources, use the menus in DSD+ to
select Passive Digital Monitor mode and then to select the audio input device that carries
the digital audio signal
. When running in this mode, DSD+ can be used to monitor conventional
analog and supported digital signals; DSD+ will not directly support trunk tracking.
That's how you cripple your brand new shiny FL install...
hiker679
Nobody's looking to 'cripple' anything, just a newbie messing around. But, it's all good, thanks for your 2 cents!
dave3825
Suffolk County NY
It always starts with just "messing around". Then becomes why does this not sound good, why is my cpu maxed out, etc, etc.
If you want to best out of DSDPlus, it works great with its FMPX tuner linked directly to DSDPlus, compared to using SDR with a virtual cable.
a417
Ugh, this video is from 4 years ago. Let it die.
Incorrect.
You may think you are doing something advantageous or sneaky, but you are not.
<snip>
You are eliminating the programs ability to do what it does best.
@hiker679, you disagree with definition 3 of 3, section 2?
Highly specialized pieces of software always have a manner in which the developers have designed for maximum operational capacity. Use them as designed and you won't have these problems. Use FMPx.
