Robert43055
Anybody know of a good antenna that works well with the simulcast for a handheld unit BCD396xt? I have the RS 800 MHz antenna , anything better
With simulcast less is better. You may want to try the stock antenna, the only one I haven't tried yet.
I have tried several antennas on my BCD396XT which have worked well up to this point and they all have performed poorly on the city sites. They work fine on the state and county sites. About all you can do is move the radio around until you find the sweet spot.
Turning on the P25 LP Filter helps a little.
I was getting the fire dispatch fine while it was on. Up until now I have never had a problem with any MARCS-IP sites.
I guess it's time to start saving up for a Unication G4/G5.
I'm using a Yagi directional antenna for the feed.It work in a downtown building, it works well on my drive in until I get downtown and then it's all distorted, your city wide feed sounds excellent though, no distortion in it at all.
The tones are definitely when the channel is restricted for emergency use. I hear them every 15 seconds or so and they stop when someone says "you can open the channel back up". I used to hear this feature on some radio systems in the Cincinnati area.
Thanks. Forgot about that. Good I'm glad they added it in.
Also XTS5000s are going for pretty much nothing now. If your good with CPS you will have a wonderful handheld scanner. I used an MTS2000 for years.
I've put all the old analog channels into my digital side and all the old analog channels are also in my analog system. That way I don't worry about which ones switch.
P.S Hearing July 31st for CFD switch over.. Not sure when the suburbs are switching but it should be pretty soon also
CPS?
CPD ...Couldn't hear anything until I loaded the Bixby (groveport) site ...I'm in R-burg loud & clear now.
Any distortion at all?
