G-Series Not Showing TG number
I have a DMR system programmed into my Unication G5 as individual frequencies, and set to monitor mode for each frequency, and then in a scan list (mode) on one knob position. I'm hearing the conversations fine, but they aren't displaying the DMR TG ID, it just shows DMR. Does it not show DMR TGIDs? I thought it did on other DMR frequencies monitored. Just to mention this is for a large music festival with dozens of TGs being used. Attached is my set up for the frequencies...
druhe
Southwest Pa
I am experiencing a similar situation. I have one zone for several amateur DMR repeaters, the display does show the TG and UID numbers. In another zone I have a commercial system programmed identical to the amateur channels but the display shows DMR / DMR exactly like your display. The only difference to the two systems that I can think of is the commercial system utilizes RAS where the amateur system does not. I do not know if this is the cause but it's the only difference.
druhe
Southwest Pa
I just programmed a second commercial system that does not utilize RAS and the display is displaying both the TG and UID as it should. Apparently RAS affects the way the Unication's display DMR systems.
Thanks for the update.
