G2 programming
ckohanowski
I have a g2 vhf hi and p25. It is already programmed with all local depts. I wanted to add a couple more frequencies to my pager but am having issues? I have latest software and am familiar with how to use it. My conventional frequency lists i am able to add the frequencies I want and save them as well as export file. When I go to the listing of frequencies I have on my programmed button which is all scan for 16 of the frequencies, I do not see the new frequencies I added to be able to replace some of the others. There are no passwords set up and I have been able to change frequencies that were already programmed but can't add any of the new ones as they don't appear. Any help? Thanks
It only allows you to have a max of 16 scanning. Did you remove one and add one on the PPS?
Okay let's look at what you are doing...
1. You are making sure the frequency and mode is in the range of your G2?
2. You are entering them in E3?
3. You are adding them to a new knob position and setting it up as MONITOR mode in E7?
4. You are going to the Zone/Knob position in E7 where the scan is set up and attempting to add it?
ckohanowski
I have all the correct frequencies in my frequency list. Have saved it exported it imported it so it is there. I want to remove 2 frequencies from my existing 16 channel list without deleting and redoing if I can. When I go to knob selection 1 where the frequencies are scan all there is the box on the left and the box on the right to add and remove the frequencies from the list. I was able to remove one of the existing and add a different frequency from the existing list but the 2 new frequencies I added to the scan list do not appear and I can't figure out why.
