G5 programming help
toddnbarbie
Cincinnati,ohio
Im trying to get my G5 to un-mute the speaker icon. Can some one look at the file and advised
I think its an issue in the tone alert,
thanks for any help
APX8000
Sarcastic Member
AES-256 secured
Tab 4 make sure you have all your Group IDs under P25T TGID column, alert mode as Tone and Alert tone as none.
Tab 5
Click knob position
Scroll down and make sure Alert mode is Tone.
toddnbarbie
Cincinnati,ohio
Thanks so much ,that got it working.
I spoke to David from Unification today at Indianapolis FDIC and He stated the same, I just forgot to check Tab 5.
Thanks again
N6ML
In my experience, it's "Alert Mode" for the "Knob Position"on tab 5 that must be set to "Tone". All of my TGs (tab 4) have "Alert Mode" set to "None".
This is clearly a defect, but it sounds like Unication doesn't want to acknowledge it (from what I've gleaned from other threads). Setting *Alert Mode* to "Tone" (v.s. "Virbrate", etc.) should not have anything to do with whether or not the audio is muted.
APX8000
Sarcastic Member
AES-256 secured
It was discussed in the threads. Some of us had to change over 700 talkgroups to bring the audio back when they released the firmware that required it. It is not a defect but had to do with receiving QC-II tones over a P25 talkgroup.
Haley
Just had this happen to me. Why does PPS do this, anyone have an idea? Its irritating. Is their a logical reason?
APX8000
Sarcastic Member
AES-256 secured
See my response above. The issue is because of a firmware change to allow QC-II over a P25 talkgroup. All of us had to change all our group IDs from None to Tone. I think back then it was like 700 plus I had.
Good news is the last firmware and the Phase II firmware it’s still Tone.
Haley
I see, somehow missed that. THAT does make sense. Thanks!
