GE Orion Programming Cable
kem554991
I'm looking at setting up a mobile dual radio install and space is at a premium. The GE Orion looks like the easiest solution. I can find plenty of radios but very little information on programming. Does anyone know where I can find a programming setup at a reasonable price? I'm also looking for information on a dual-radio cable if anyone knows about that. Thanks!
DisasterGuy
Maryland Shore
The Orions are fine radios. You will need the following:
TQS3389 - Conventional ProGrammer PC Software
CA101288V15 - Shop Programming Cable
CA101288V10 - Remote Mount Dual Radio Cable
Two radios of your required bands
Two power cords
One system or scan control head.
kem554991
Thanks! I found a source for the programming cable and got ahold of he programming software. I'll hopefully be ordering the UHF 440 unit tonight and then a VHF-Hi trunk mount later when I've had time to figure out programming and find a source for the dual radio cable.
timkilbride
Linn Co Iowa
Make sure both radio's have 512k boards in them. 256k won't work. Same firmware in both radio's is highly recommended as well.
Tim
mslawson
Los Angeles, ca
Hi, Im looking to buy a GE Orion radio on Ebay. Where did you end up finding the programming cable and software? Thanks
kem554991
I'm afraid I'm not much help here. I actually have yet to purchase the radios and programming cable due to lack of funds. I did find the software but I don't recall exactly where as I looked several places...
I will say that from what I gather the Consolette and Remote Mount units use different programming cables so that's something you might want to keep an eye on.
DisasterGuy
Maryland Shore
One thing to remember with programming cables is that there are two versions. One requires the Programming Interface Module and one doesn't. The Part Number is listed previously doesn't. It is the same cable used with the M7100 and is available from any Harris dealer including New London Technologies and Eastern Comminications. The software can also be legally obtained through both sources.
iceburgh
edward_phi@yahoo.com
I own the uhf model of Orion. Does anyone know if the software runs on Windows 7 64 bit?
Sent from my LG-H345 using Tapatalk
iceburgh
Thanks Disaster Guy. That response was quick. Do you have this programming cable for win 7 64bit? Also need software and dont have db9 connector on my laptop. My Orion has been sitting in the closet for 5 years. Never used it. Are you an authority on these radios as I am a senior citizen who only has two more years left ln my GMRS license.
DisasterGuy
Maryland Shore
Can't help you with software as I am an enterprise user and it also requires license authentication. Would recommend finding someone local to do the programming for you.
Sent from my SM-G900V using Tapatalk
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
Tim
256k or 512k, or even a mix of the two will work for Dual-Radio installations.
The REVISION of firmware must be the same in both radios. For conventional use, Group-30 is the most bullet-proof.
It is only when you mix an Orion and a Jaguar 725m or M7100 can you only have a 512k Orion as the other radio.
timkilbride
Linn Co Iowa
I am running R18 on Win 7 64bit. I'm also using a USB to serial converter with no issues. The same converter gets used on M-RK's, M7100, P7100, P5400, P5100. I may be missing a radio or two but it seems pretty bullet proof.
Tim
