Getting Inmarsat through my wall- awesome!
MrBungle
Did over a decade as a LEO. Hated every second.
North America
I'm in Utah, and it's cold out so I'm not sitting on the back patio using my SDR and antenna. I tried it inside. While it's not ideal (that constellation is super weak), it works way better than I thought it would. I'm going to order some better coax. I also have a new mount coming tomorrow.
MrBungle
North America
Would my antenna benefit from a solid copper wire? I currently have strand copper wire.
thebaldgeek
thebaldgeek
SoCal
Fantastic effort to not give up and make the best of your setup.
Whats the app that you are using to get the cross hairs?
I've had to talk many people into moving their helix out of pointing out a window to pointing through the wall or roof.
The windows in the USA often have a UV filter coating, ie, thin metal and it really blocks RF. Its frustrating for people as they can 'see' the antenna, but yeah, moving the helix out of the window and pointing it through the roof/wall and it will go much better.
If you have any wriggle room, try different spots on the wall, often the wall / roof construction changes in unexpected RF ways.
@MrBungle There wont be much difference. Better still is 4mm coper tube.
Have your read these L-Band pages? How to build an L-Band ground station.
Its got some good hints.
spongella
W. NJ
Nice setup and decoding of Inmarsat marine messages. I dabbled with Inmarsat antennas connected to an RTL-SDR.com SDR several years ago, very exciting. However I could not find software to decode. After much shopping around confusion I decided to call it quits. But you seem to be very successful and the Inmarsat messages have quite a bit of interesting information for the marine radio hobbyist. Thank you for sharing.
dlwtrunked
As it is drywall (supported by wood), that works as you found. I get better signals but then again I am using a 4 ft dish antenna (in my bedroom) and a better pre-amp. If you have not seen the list below put together by Sergi (an myself helping), it is the *best* that you will find of INMARSAT frequencies. Log In
I expect we will check soon to see if it needs updated.
MrBungle
North America
Yeah so thanks to you for your website and information! I've been on your pages several times reading through. I've gotten some great information there. I've read all over the window is a no-go so I went right through the wall. I have a better mount arriving today so I'm going to work on that.
The app is Satellite Finder in iOS.
I noticed an hour later, once it got darker out, the signal vastly improved, like a ton better. I also noticed that while the frequency was locked all night long, it wasn't set to auto- meaning it sat on the one single frequency and decoded all night. The frequency never changed and was decoding this morning. 1.537.700.000 all night long.
MrBungle
North America
Thank you, I just signed up.
thebaldgeek
thebaldgeek
SoCal
Depends on what service you want to receive and what you want to do with the data.
For STDC Marine you have quite a few options, they are listed and explained on this page: STD-C aka InmarsatC aka NCSC aka EGC aka Marine Messages.
For ACARS, your have two, SatDump and Jero. Jaero is the most popular. Details are here: Ins and outs of Jaero.
I cant log into that link. Can you please confirm that your list on my site that you gave me last year is still up to date.
A _lot_ of people use the L-Band page to reference those frequencies and modes: How to build an L-Band ground station.
The frequencies are at the bottom of that page.
Thanks.
thebaldgeek
thebaldgeek
SoCal
You can read all the messages from 4 of the Inmarsats (not just the one you are 'under') on my site here:
Also you can search the past months messages on that page.
If you have any suggestions for the layout or filtering of marine messages, please let me know. I've been asking folks for help to better make use of the messages, how to filter and display them, but so far no one has offered any insight.
MrBungle
North America
So another question- today the signal went to nothing, but as the sun goes down and later in the day, the signal is coming back into view on my waterfall. I don't remember this happening last summer when it was warm-maybe it did and I don't remember.
New mount came, way more stable.
dlwtrunked
Thanks.
To get to the link, join the group (no cost), then log in, and then go to the link.
dlwtrunked
Thanks.
In case it was you, here is the current file. I think one typo was corrected since the original list. I have been too busy with other projects to check current status. (Other project have focused around the HF trading stations and radars.)
  • INMARSAT frequency list.pdf
thebaldgeek
thebaldgeek
SoCal
Keep in mind that the Inmarsat's are in a geosynchronous orbit. They wobble in a big fat sloping '8' in the sky.
If you happen to setup your helix when the sat is at the top or bottom of the orbit, then yes, you will lose it at some point in the day as the helix beam width is narrow enough for the sat to drift out of the sweet spot.
The RTLSDR patch antenna is much boarder and wont have the issue, but it also wont work anywhere near as well. (Or work much at all inside a house!).
The solution? Peak up in the middle of the orbit. Then the beamwidth will still get the tops and bottoms of the orbit. Yes, I have set an alarm to get out of bed at 2am to do this, but I am a lot more hard core since so many folks rely on the site data.
Tips and links are here: Inmarsat - Finding ‘your’ sat.
And here: How to build a C-Band ground station.
MrBungle
North America
Ahh yes I forgot about that-thanks!
