Got tired of the dim pale blue BCD536HP display
seth21w
Somewhere monitoring the air.
I used to love the blue screen of the bcd396t i always wanted that model when i was a kid, i was mad that my bcd346xt had orange instead of the blue. But i had no need back then for digital and i couldnt afford it at the time making minimum wage. Lol ahh the good old days
tumegpc
Southern Oregon
436HP color screen mod
Pretty simple to add color to your 436HP LCD display. Remove the six screws on the back case and with the scanner front facing down , pull the front and back case away so that the keypad and contact stays intact. Cut the transparent color film 46mm wide x 57mm long - this will give you enough room to tape it secure to the LCD metal frame.
Attach one piece of clear tape on top of the color film and metal frame , you can add a piece small on to bottom . Do not touch the LCD - I used a pair of tweezers to position and hold it in place while applying the tape .
budevans
Cleveland, Ohio
Thank you for the photo's and instructions. That's a big help.
In May of 2015 a RR member did virtually the same thing. He found colored film at a Arts & Crafts store.
Here's a link: http://forums.radioreference.com/uniden-tech-support/313087-mult-color-screens.html
LOL, that was your post from 2015.
OK, so which film type gives the better visual results?
tumegpc
Southern Oregon
The problem is the 436HP from 2015 had a different set of LED's . They were brighter and had more of a whiter color. The new LED's are not as white and more pale which make the color tones different and less vibrant. The Yellow film that you see in the picture is working best so far. My plan is to try in on my R/S 668 - Their "Low" brightness setting is Uniden's "High". I can probably use any color on the R/S 668 !.
mancow
N.E. Kansas
I really like that color.
Also I would suggest laying one of the extra sheets over the front cover while you work on the LCD portion. I find that tiny dust specks tend to gather on the inside of the clear window if left off​ too long. Those drive me mad when I notice them after resembling something.
tumegpc
Southern Oregon
So true about the dust . I use a dust off compressed air and photo lens dust tape to remove it. And a pair of reading glasses to zoom up . LOL
crazzycatman
North Charleston SC
did you use 1 or 2 layers of the yellow film? thanks
jonwienke
More Info Coming Soon!
VA
Blue masking tape works great to remove dust buildup. When I'm modding scanners, I run the sticky side of the tape on surface of the LCD screen and the inside of the bezel just before reassembly. It cleans up any residual dust very effectively. It also works good on digital camera sensors.
dave3825
Suffolk County NY
rs16
I like the yellow also. Very impressive.
Do you have to leave the backlight on to get this effect?
If yes, won't that burn out the backlight rather quickly?
INDY72
Indianapolis, IN
Led last years so no worry there
Sent from my LG-K330 using Tapatalk
