So can anyone confirm, do I need just the GPS TX to the 436 or do I also need the ground and gps RX
I see both listed
I see both listed
First, thanks to Jasonyohon for showing the way. I picked up the same items he used -- RCW-109 cable from Newegg -- and just as a precaution, checked my cable's wire colors/pinout against Jasonyohon's nice diagram. Yikes! the Uniden mini four-pin was reversed from his. Suddenly things clicked into place. With everything wired up and working, the serial data ground was on the cable's black wire instead of red (ahhh ...), and GPS transmit was green --> green. It APPEARS that Jasonyohon's cable had the wires reversed when it was manufactured, and yours might have been, too. My connections are:
GPS TX green --> Green on the RCW-109 cable
GPS RX white --> Red on the RCW-109 cable
GPS ground --> Black on the RCW-109 cable
Not used: White on the RCW-109 cable
I hope this might save some frustration/head-scratching
John, N4VU
You need a GPS that is NEMA0183 data sentence that has a RS-232 protocol output. The Uniden radios REQUIRE RS-232 they WILL NOT WORK WITH A USB interface. Have seen some GPS pucks that have the 5 or 6 pin DIN connector that have RS-232 DB-9 and USB pigtails and may be switched between the 2 interfaces but do not think yours will do it.
The 4 pin jack on the Uniden radios is used on many digital cameras for a USB interface but on the Uniden radios it is RS-232.
I imagine since it does do NEMA0183 you may be able to do a TTL to RS232 level converter not sure what handshaking is required.
David Kb7uns
