GPS
KO4IPV
Working with the Uniden SDS100 and the mobile GPS attachment connected inside car , there is a small black box and a large black box witch one is meant to be put in window ? The small one or the large one For optimal operation of the GPS or is it both ?
RandyKuff
Lorain, Ohio
If your using the Uniden kit... Uniden BC-SGPS Universal GPS Kit...
The smaller box is the GPS receiver...
n1chu
Farmington, Connecticut
... not to butt in but if the smaller one is the receiver the larger is the antenna? (It’s the antenna you want in the windshield.)
n1chu
The smaller should sit on the dash or attach to the windshield. There is an unboxing video I found by doing a search for Uniden BC-SGPS.
Mofo84
The small box gps module goes on dash and connects with rj14 cable to the bigger converter box that is powered by 12volt plug and a rs232 to USB cable goes from the bigger converter box to the USB port on the sds100
RandyKuff
Lorain, Ohio
n1chu
The small dongle is the GPS reciever module... The same one that plugs directly into the SDS200...
KO4IPV
Thankyou so I have the smaller box in window and the larger box under dashboard would this be correct it seems to be working fine.
RandyKuff
Lorain, Ohio
Whatever works... As long as the GPS isn't obscured from the satellite signal ...
The rest of it can be placed however you want...
