Gre Psr-600 "q"
SCANMUNCIE
Delaware Co, Indiana
Gre Psr-600 "questions"
I just got my PSR-600 and have a few questions:
1. I was wondering if there is a way to slow down or show only the talkgroup label, It flashing between the talkgroup label and system name so fast that its hard to tell which talkgroup it is on..
2. Also I have noticed that some times it will show only the 800 freq and other times it will flash between the 800 freq and the talkgroup id number (dec/hex). Is there a reason it doesn't do it all the time?
3. The other thing I have noticed is the in the TSYS in the Analyz mode it has the Site incorrect for the system that I'm monitoring. Now if I CC Dump and use unitrunker the site is correct along with my agency portable has the correct site matching unitrunker so I'm assuming that the onscreen display on the PSR-600 shows it incorrectly. In addition it shows the connect tone incorrectly also.. Or I'm doing / reading something incorrectly..
spooney
Indiana
Question #1 : Go into PROG - GLOB (F3 key) - LCD Blink On (change rate to 250) - LCD Blink Off (change to 100) This setting works to my satisfaction.
Question #2 : No fix for this. You will see the freq only when channel is open. The TGID is only visable when the signal drops (during the delay).
Question #3 : I think GRE is aware of this and should be fixed in the next upgrade.
mikey60
Oakland County Michigan
If it's a P25 system, keep in mind that the radio displays the site number in HEX mode, so this may be what you are seeing.
Mike
