AZScanner
GRE did (does) care about it. However, as mentioned in the posts pro92b referenced above, there are some problems with implementing it in the current PSR-500 family hardware.
Here's some more detail on the difficulties described in those posts:
The primary problem is code space. That is, at present, "P25 encryption muting" won't fit in the hardware where it needs to run. In order to implement the feature, substantial effort is required - not just for the feature itself, but to move other functionality around so that the desired feature would even fit in the hardware. Moving that other functionality, in order to make room, involves substantial risk - the risk that these changes would cause many other "things" to break.
It's not merely a matter of "let's add P25 encryption muting to this one module, because we know how to do that". Instead, it's that, preceded by "let's move a bunch of functionality from one place to another, and add all of the internal communications required to handle that 'move', hoping we don't break anything or run into any other roadblocks in the process, and hoping that the internal communications can even handle the moves in the first place".
I know this is a firmware thread but my ancient BC250D and 796D don't have that newfangled fancy P25 Encryption Skipper doo-dad thingie on them either. So I created a little workaround.
Don - does the protocol for the 500 allow you to emulate pressing the scan key, and does the display indicate when an encrypted transmission is received? If so it should be a fairly simple matter to emulate this feature via control software. It's how I did it for my old unidens. On my 796, when it hits encryption, the display alternates P25/ENC instead of the usual P25/LNK. Whenever it saw ENC instead of LNK, I told the little control program I wrote to hit the scan button. Problem solved. Maybe you could add that to Win500 for these guys.
-AZ
