prcguy
- Joined
- Jun 30, 2006
- Messages
- 18,881
- Reaction score
- 15,307
Did you bond the new ground rod to the house main ground rod as specified by NEC? If not that can be dangerous on several levels from causing the ground potential on the radio connected to that ground rod to be much different than everything else in the house. As a young person I did this and my one radio connected to the isolated ground rod had about 90 volts AC on the chassis and whenever I disconnected the antenna it shocked the heck out of me.
The other problem is if you were to get a lightning strike the different ground potentials can cause much more damage to equipment in the house. Its fine to experiment and see how grounding affects noise but I would not recommend leaving an isolated ground rod connected to your radios.
I used an outside ground rod (just outside the window) and saw one-half S-unit increase in signal with no apparent increase in noise. It's an incremental improvement, I think.
