Harris M7300
Chris52
Leonardtown, Maryland
Can anyone help me out here ? I’ve never seen this warning before. Thank you in advance
Signal3and2
WY
It means there's no communication between the control head and the radio chassis. Check your CAN cable and CAN terminators, as well has power to the chassis. If it's a front mount, you'll probably have to crack open the radio to see what's going on. There's a few reasons a front mount might do that, but not nearly as common as with a remote mount radio.
Chris52
I have an all band Harris M7300 mobile radio that I use for amateur radio and GMRS use (VHF and UHF) with an all band antenna and after a few seconds the other persons traffic gets distorted prior to doing ANY transmissions. Depending on the person determines how bad it is. I know some regular ham branded radios sound hot as it is I.E. Yaesu. I’m curious if this is a band selection issue in the software of my radio or the radio itself ? Maybe a speaker issue ? Typically if it was the radio I’m sure it would heat up as I’ve had this issue in the past with a Motorola and it would be too hot to touch after doing some transmitting as well as my audio sounding distorted but this radio is fine. I’m being heard and commented on how great my audio is so I’m stummped. Any help would be greatly appreciated. Thank you in advance !
nikronzo
fog
There is a lot going on in this post. Can you say more about the distortion? The fact that it varies based on who's talking seems odd. Could it be a wideband repeater programmed narrowband, or vice versa?
Chris52
I apologize for not explaining things correctly but I’m trying lol. While using the VHF, UHF side of things for local ham repeater use the voices on the other end are distorted, like it’s off frequency. When I transmit I get great comments on my audio. Some suggest I get the radio “tuned” but I have the slightest clue on how to go down that road. Thank you
