Harris XG-25P Can't put into program mode INV SYS
merlin
DN32su
Do i need to send the command as the radio is booting up? Ive been able to use putty before with thales25 radios with no problems, but for some reason this xg-25p is killing me.
Wait til the radio boots then send the command. I should quickly respond with "Restarting" and booting.
Command atz0 should respond with "*" or a short hex string. If nothing, your port may not be right or your radio
has a fatal error.
It won't fix the INV SYS error, but it does tell you the radio is still talking to the outside world.
hsmcco
Busted out the CF-19 and serial cable. Going to get to the bottom of this.
merlin
DN32su
Don't feel bad, I have gone so far as JTAGing a radio and that is not for beginners, or even intermediate level.
hsmcco
Even using the cf19 with serial cable isnt doing it. Completely out of ideas at the moment.
hsmcco
Experimented with some other XG series radios. All radios were able to enter programming mode successfully but the XG-25 stuck in inv sys.
adamr368
NJ
Have you tried the format flash drive option? Voice Annunciation>Voice Annunciation Management>Manage Radio>Format Flash Drive. If you can get this to work, it should blow out the personalities and allow you to reload a new config.
hsmcco
Thank you for this information. This actually solved a problem I was having with another radio of mine, but unfortunately was unable to fix the xg-25. Im fairly certain that the radio is unable to communicate with the computer as ive replicated the issue on another radio with it being able to go into programming mode from rpm.
