Having trouble programming my Pro-106
ElJDub
I am wanting to program my scanner for two different towns, but here is the issue. One of the towns is Nashville, which is already in the preprogrammed V-Scanner folder of TN-GA-MO, but the other is one that I have to enter in manually. I'm guessing that because of the way the Preprogrammed info is loaded into memory, when I try to enter the second town in manually it winds up under Atlanta's sub-menu.
I would like to just set up the objects manually, but I don't know enough about what I'm doing to do that. The other town is fairly easy to set up this scanner for, but I have to rely on the pre-programmed data for Nashville. But when I load the preprogrammed data it wipes out what I set up for the other town.
I'd appreciate some help. Thanks.
