- Joined
- Feb 14, 2024
- Messages
- 95
- Reaction score
- 2
I am getting a heap error on my pro 106 scanner. Do I need to send it in for repair?
Well if you used programming software (a la Win500 or Arc500) you could zip up and post your programming export as an attachment here so we could have a look & better help you but... Did you have a look at the guidance provided in the wiki given to you in post #2?None, I program manually. Thank you for the reply. How do I correct this.
It's your call, but if you're already willing to pay money to have the scanner repaired, why not try downloading some decent programming software, (ARC500 or WIN500) so that you can read your entire scanner configuration. Then you can see if you have some unassociated talkgroups that you might not be aware of, and correct the issue by yourself.None, I program manually. Thank you for the reply. How do I correct this.
I programmed a PRO-197 manually for a large trunked system. It took forever having to enter the 2-digit code for each character in alpha tags for hundreds of talkgroups. I also wore out the scroll control on a Uniden scanner entering alpha tags programming a similar trunked system. Then, I discovered the blessing of using software. It's great knowing how to program manually when you need to make an entry and a computer isn't available, but it's sooo... much faster and easier using software!Go to all your trunked systems, one by one, look at each talk group and make sure the "System " using each talk group is listed on the TG, one of your TGs is not associated with the "Trunk System " , fill it in and the error will be corrected. I also pgm by hand and sometimes mistakes are made ,
Back in the day when I was writing for hobby radio magazines and reviewing scanners for them, the first thing I always did when reviewing a new scanner was program a few conventional frequencies and a small trunked system by hand. Then I moved to software for serious programming. Made for a more complete review, plus if anything went wrong, I had a good idea what to do about it.I programmed a PRO-197 manually for a large trunked system. It took forever having to enter the 2-digit code for each character in alpha tags for hundreds of talkgroups. I also wore out the scroll control on a Uniden scanner entering alpha tags programming a similar trunked system. Then, I discovered the blessing of using software. It's great knowing how to program manually when you need to make an entry and a computer isn't available, but it's sooo... much faster and easier using software!
