I was scanning 406-420 today and found:
406.75 - cc
- SYSID 4B1D
- 90 khz tone
# 410 406.7500
# 418
# 474
# 498
I suppose I ought to be able to use the # above to determine what frequencies go next to them, but I don't know how.
It apears that when I hear transmissions on 406.75 I also hear them on 408.95. I also think that there may be a very short delay when I hear them on 408.95.
I am monitoring using both a handheld with stock antenna as well as a BCD996T using an external ant with some really pisspoor mini coax from 10 years ago with major infiltration by the elements and a 144/440 Cushcraft vertical. Signals are about the same (weak - no S-unit readings).
Just wondering if anybody has a clue as to where I might be hearing these transmisisons from considering I'm in East Ohio (just south of the WV/PA/OH border at about 1200 feet).
All I've managed to pick out thus far are a few little things such as:
"control to medical"
"blah blah duty officer"
"the A-side outer door needs opened"
Heard a mention of security.
It's interesting because I have looked up and found the usual bandplans for the 406-411 range and one of the frequencies that I can hear is in the second plan and one is in the third plan.
I figure likely it is going to be Pittsburgh area or downstate WV.
Not sure if it is fed or military based upon what I've heard so far.
Any ideas?
Mike
406.75 - cc
- SYSID 4B1D
- 90 khz tone
# 410 406.7500
# 418
# 474
# 498
Any ideas?
Mike
