Help,about DMR Tier III area.site
KentsonShum
About DMR Tier III area.site:
I purchased DSD + 2.235 / Fast Lane Release. When I scan the Hytera Tier III system, how can I change the Networks file, I cannot convert the IDs into the CPS-P3 numbering scheme. I have read many days ago in the forum, but I still can't solve it. I hope everyone can help:
1) When using 2.235, only "L plus number" is displayed below the Event log, but 1.0.1DSD + 1.101pt [Public Release] does display "Current site: L1-1.6",
2) According to DSD + 2.235 scan, my current frequency shows "DCC = 1 CSBK ECC / RAS Bcast SysCode = 10.0000.00000101 AB;" The data calculated according to this should be:
Default model: Large (10), Default NID: 1 (0000), Default Area Size: 5, Default Area: 1 (00000), Default Site: 6 (101)
3) I have tried to add "TIII, 1,‘ Name ’, 5, CPS-P3” to DSDplus. Networks, and also added “TIII, 1,1.6,433.6625,0.0,0” to the .frequencies file. But nothing happened.
4) I need to know now if I can convert the TGs and radio IDs in the event log to the CPS-P3 numbering scheme
Thank you for your help
81038
radio241
Wisconsin
Not sure if this is related, but...
In 2.197 DSD showed DMR Tier III site IDs correctly, such as L1-5.6;
In 2.235, using single dongle trunk tracking, it shows most sites as L1 (on the L size Tait and Mot systems around here)
If using two dongles, the site ID shows correctly.
KentsonShum
Thank you for your reply, I now use single dongle and with DSD + / FMP24 Fastlane suite. In the DSD + event log menu, select "Open network / site loader". Then select it to force it into a CPS-P3 numbering scheme. It seems that SDR # / DSD Fastlane does not read the network settings. It may be a problem that I haven't set up myself.
cg
Connecticut
I have a Hytera TIII that I can monitor 2 sites on.
If I remove all my records on the system, the Network/Site shows up as:
Current Network: L13
Current Site: L13-1.4
The bottom margin shows:
TIII (HYT) Site:L13-1.4 DCC:3 NL:1.2 1.3 1.5
I believe 13 is the default ID although it perhaps it may change by manufacturer, installer or country.
I add the system along with CPS-P3 to the Networks file:
TIII, 13, "xxxx TierIII", 5, CPS-P3
and it runs fine with all the IDs showing up properly.
chris
slicerwizard
Toronto, Ontario
TURN DOWN THE GAIN! 50 DB IS FAR TOO HIGH! YOUR SCREEN GRAB IS MAKING MY EYES BLEED!
KentsonShum
chris
thank you! Let me try
KentsonShum
Did you solve this problem?
I had the same problem with the 2.235.
In HYT TIII site,it only shows the site like LX-XX not LX-X.X .
The CPS-P3 didn't show correctly.
It is not completely solved. Even I used FMP24 / DSD + Fastlane, I need to select "Site loader" in the "control" menu to force the change to the CPS-P3 numbering scheme. If I don't do this step, only area (L + 5) is displayed instead of area-site (L1-1.5). From the scanned Syscode, it should be automatically adjusted to CPS-P3, but I don't know why it is not.
cg
Connecticut
Perhaps send a raw recording file to DSDPlus author. You can type "r" in Event log window or use the menu and make a 20-30 second recording.
It sounds like it isn't recognizing the System ID until it is forced to use the site chosen.
chris
KentsonShum
是的,我從掃描數據中獲得了SysCode = 10.0000.00000101。正常的計算結果應該是(00000 + 101)L1-1.6,但是我的快速通道計算是將最後八位數字(00000101)一起計算為5。我嘗試將數據發送給作者,希望他不會忽略它!
slicerwizard
Toronto, Ontario
Yes, I got SysCode = 10.0000.00000101 from the scan data. The normal calculation result should be (00000 + 101) L1-1.6, but my fast channel calculation is to calculate the last eight digits (00000101) together as 5. I tried sending the data to the author, hoping he wouldn't ignore it!
bh4qbv
I had send a copy of raw data to the author,he told me the issue should be resolved in DSD+ 2.242.
KentsonShum
And is it?
I have received an email reply from the author saying that "The‘ L + number ’issue should be resolved in DSD + 2.242.” "New version 2.242" popped up two hours ago, but I failed to download, try downloading tomorrow or wait for their email to link!
