Help a total newbie???
PoWdA
Denver, Colorado
Hello!
I am a total newb with these scanner things and am confused at the moment. Basically, I bought my girlfriend who is a journalist a Radio Shack PRO-528 about a year ago and it has not gotten much (any) use because we really don't know how to use it.
Tonight, I think I figured out trunking and I input a range of frequencies and am currently listening to a bunch of fire and medical calls. I have many questions now.
I programmed using the directions I pasted in below.
CC ONLY PROGRAMMING - MOTOROLA SYSTEMS
PUSH DISPLAY
1. E/PGM, then TRUNK All bank numbers flash.
(You may need to do this twice before banks flash)
2. Bank number E2-800
3. E/PGM 1 Prog F
4. DOWN arrow twice 7 CC Only
5. E/PGM CC OFF
6. an arrow* CC PL1*
7. E/PGM 7 CC Only
8. UP arrow twice 1 Prog F
9. E/PGM xx1 ch 000.0000
19. Enter 1st freq. for example 856.2625
11. E/PGM 856.2625
12. UP arrow xx2 ch 000.0000
Enter remaining control channels (up to 4)
13. E/PGM xx2 ch xxx.xxxx
14. SRCH Trunking starts
* Push an arrow until you see the Band Plan for your system.
PL1: If ALL the frequencies end in 125, 375, 625, or 875.
PL2: If freqs. are below 869.0000 and end in 125, 375, 625, or 875 AND if any frequencies end in 000, 250, 500, or 750.
PL3: If ALL freqs. end in 000, 250, 500, or 750.
PL4: If freqs. are below 866.0000 and end in 000, 250, 500, or 750 AND if any freqs. end in 125, 375, 625, or 875.
I entered PL2 as the following are the frequencies I entered (taken from this link Lakewood / Wheat Ridge / West Metro Fire Trunking System, Lakewood, Colorado - Scanner Frequencies)
001 1 Green Mtn 01 851.25000c 02 851.71250c 03 851.91250c 04 852.22500c 05 852.68750c 06 852.91250c 07 853.30000c
08 853.53750c 09 853.75000c
Now. I am only getting fire it seems. I would like to get police as well, specifically lakewood, denver, wheat ridge, arvada, littleton, and jefferson and denver county sherriffs.
Any advice?
Also, I will probably have a ton more questions. I am enjoying this so far, would love some advice!
jrholm
Big Bear
It looks like most of what you want to listen to is digital and your scanner don't do digital
jeffreyinberthoud
Banned
BERTHOUD COLORADO
I believe that Lakewood is a ESK edacs system Im thinking your scanner will not track it its to old
AS a Newbee you might want to check DB and find convetional freqs just to confirm scanner is working right
then if you want to try a trunking system under Adams county program the westmister/arvada edac system your scanner should track that one
jeffreyinberthoud
Banned
BERTHOUD COLORADO
also come to the colorado forums page there are many nice people that will help you and welcome to the group
