Help getting started with Uni-Trunker
Tim
Milwaukee, Wi
Hiya all..
Ok, here's my setup at the moment. PC with Windows XP and Laptop with Vista. I D/L Uni-Trunker on both and have descriminator tap on a BC780 done by a friend. I've used a few different audio cables and the program shows "No signal" on both.
Is there a certain audio cable i should be using to connect from scanner to computer? I should be putting the cable into microphone input on laptop, right? Is there troubles with it working on Vista??
Any ideas, tips? FWIW, I tried the Uni-Scope and the red line does move, although slightly.
Tim
Deeke
You may have to adjust the volume in by going to the volume recording controls.
Also in Unitrunker, goto the options menu and tab over to "Decoder is" and make sure it is online
