help me with latest airspy sdr software and plugins
sierratango76
Italy
Hello,
I've buyed a new i9 laptop with windows 11, I've installed the latest airpsy sdr version (1.0.0.1921 64 bit version) but I've a problem with plugins like tetra decoder and dmr plugins that are not showed on the software. Is there another way to install them in the latest airpsy sdr version? in the older version I remember that the dlls should have been placed in the airspy sdr folder and a line added of each plugin inside the plugins.xml file, but this doesn't seem to work now. Anyone can help me please? thank you!
ormetkruper
Dals Langed, Sweden
For DMR plugin use the 32-bit version and the SDRsharp.dotnet8.exe to get it to work.
Just copy the plugins to the plugin folder, no need for a line in plugin.xml anymore. Sort each plugin in a sub folder in the plugin folder for easy view.
sierratango76
Italy
ok I've installed the airspy 32 bit version, I've placed the dlls plugins into plugins folder and now I see them from the software after launched the SDRsharp.dotnet8.exe. But now the problem is if set the correct frequency of dmr or tetra station, the plugins works but I no hear the decripted audio. If I deactive them I listen normaly the encrypted audio signal. Now where's the problem? I'm going a little crazy about it
PDXh0b0
Woodland, WA
sierratango76
Italy
ok tomorrow I'll try that dmr fix..I hope to resolve. Do you know if there's a fix also for tetra decoder with latest airspy 1921 version? same problem of dmr plugin
