HELP PLEASE
Slangnbang
idaho
Hello I am from Idaho and I would like to listen to Law talk and the only frequency is showing ISP security and that’s not the one I’m looking for. I’m looking for Pocatello Chubbuck and Bannock law talk I was curious on how to get those frequency linked to broadcast or how would I go about listening to those frequencies?
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
If you are talking about listening on Broadcastify or the Calls Platform, Bannock County law enforcement is not being fed by anyone to Broadcastify, so looks like your only option is to buy a P25 Phase I capable scanner. And setup your own feed for Bannock County.
thewenk
Idaho DB Admin
Eastern Idaho
The Pocatello area (and District 5 counties) are some of the very few areas in Idaho, with Law enforcement using P25, that is still mostly not encrypted. The comments and suggestions in the previous posts are all good.
  • Like
Reactions: wtp
Junior1980
Canada
Ada county feed was working good Monday around 4-5 pm but since it's not been working as the feed had kept going on and offline. I'm curious if others have noticed that as well and I would appreciate if someone with knowledge can pm me I don't usually like to posting on public forums but appreciate it as I am not personally from the USA thanks
Enforcer52
Lake Livingston, TX
A feed has a REPORT button on it that sends a message to the owner of the feed, try that and see if you get a response. Other than that no way to contact the owner or for anyone else to know what is going on with the feed status, other than it is off line.
Junior1980
Canada
Thank you
A feed has a REPORT button on it that sends a message to the owner of the feed, try that and see if you get a response. Other than that no way to contact the owner or for anyone else to know what is going on with the feed status.
Enforcer52
Lake Livingston, TX
Ada County is on the below system. Most all Law enforcement is now encrypted and only some fire is in the clear if you look at the listings.
Ada County Law and Fire agencies have migrated to the ICAWIN 700 MHz system. Fire frequencies may be simulcast on vhf and 700 MHz. The use of other uhf and vhf frequencies may be discontinued or utilized for fallback operations, as the transition takes place. NOTE: Ada County SO and Boise PD no longer utilize UHF frequencies.
Junior1980
Canada
Sent you a PM
