help programing trunking portable
harrisjt
i got a motorola gtx handheld that i want to program a trunking system to i have a system key what else should i know its a type II system and a type II radio
mlevin
Baltimore, MD
First you're going to need, a RIB (cable and box) and the RSS programming software. Then you're going to have to program the talkgroups with the wrong connect tone and an invalid radio ID. This way you won't affiliate with the system. With the GTX I don't believe you need the system key. That's only for the JEDIs. (Don't hold me to this though.) You'll also need the SysID. Ifyou don't know what you're doing, then have someone else do it for you. If you want more info go to www.batlabs.com
harrisjt
ha
i know all that its just ive never programed trunking and ive done all that with out success even with a sys key iwas coming here before i went to batboard
mikewazowski
Forums Manager
Oot and Aboot
Bullshoot. It's advice like this that could get a guy in serious trouble.
Connect tones are only used to hold a voice repeater open. It's like a pl tone. It has nothing to do with affiliation. Programming the wrong connect tone in will still allow the radio to fully transmit on the system including affiliations. He'll be able to push the ptt and get a channel access grant. The only thing he can't do is keep the voice repeater up as he's got the wrong connect tone.
I'm also kind of wondering how he would know what an invalid radio id is for the system? You're also assuming that the system admin has turned on radio id checking. Big assumption that could seriously screw him.
Doesn't really matter as you need a system key to program any radio on a trunking system unless you've got some sort of Motorola lab software.
mlevin
Baltimore, MD
Well I don't claim to be an expert but right next to me is an MTX 8250 programmed with the wrong connect tone and Radio ID. If I key up, the radio just stops trunking. I did this next to a scanner tuned to the same talkgroup and nothing happened. As far as I can tell the radio is not affiliating. Like I said I don't know for sure if the GTX works the same way. Also as far as I know (I didn't program this radio) the system key was not needed. Now this is as much as I know, and this info is what my reply depended on. Now I'm going to leave this thread alone since I'm really not an expert, and don't want to be treated like a criminal.
loumaag
Silent Key - Aug 2014
Katy, TX
mlevin said:
... As far as I can tell the radio is not affiliating. ...
It would be interesting to be running Treport or Trunker on the CC when he turns that radio on or changes TG's. :roll:
mikewazowski
Forums Manager
Oot and Aboot
What's actually happening is the radio is programmed for affiliation on ptt. It will not try to affiliate until you press the ptt button. Once you press the ptt button, the controller sees the request and possibly rejects it if you have indeed picked an invalid radio id and the admin has turned the security on.
If the system admin sees these keyups, it's possible he will inhibit your radio. Having the wrong connect tone and an invalid radio id won't save you.
Mozilla
South Florida
Trunking
What system are you trying to program for. Since you only want to monitor, GTX has limited scan list, no alpha etc. Unless its some podunk system you would probably get a lot more service out of a decent scanner such as pro 93-95 or Bearcat.
MetalManMI
I keep hearing this type of thing....so I did an experiment!
I took my authorized, issued trunking radio and fired-up my frequency counter next to it. Turned the radio on...nothing. Changed the channel....nothing. Keyed it up and got a reading on the FC...then the dispatcher asked me if I was secure!
I'm sure if the radio is programmed to affiliate upon being turned-on, it would do so. If it is not, it would appear that it acually doesn't!
Anyway....
8)
mlevin
Baltimore, MD
My radio affiliates on PTT. And BTW, when I key the radio, the controler doesn't give me a channel access. So I'm not concerned. It's very posible that the person who programmed the radio, did more then what meets the eye. And no he didn't disable the PTT.
mikewazowski
Forums Manager
Oot and Aboot
You're radio is working as programmed which probably is "affiliate on ptt". You are probably on a Smartnet or Privacy Plus system which allows this option.
If this was a Smartzone system, you would have no choice and "auto affiliate" would be the only option. Upon turning the radio on or changing channels, you would have caught a small blip on the frequency counter every time.
n4voxgill
Silent Key
New Braunfels, TX
Two comments, first you violated federal law if you do not have a MO FCC license for the frequency you keyed up.
Second, when you transmit on the control channel, the transmission is not assigned to a talk group until the controller does it. You are sending the TG info, but it must be assigned, so this does not mean you were not affiliating, it just means the controller denied your request or it could mean you were not affiliating. Either way, it was an illegal transmission subject to severe penalty.
How do people get caught, they get on public boards and run off at the mouth.
pacrat551
TX Admin
Texas
No matter how you look at it, it is not a radio that is authorized to be on the system. All the system manager has to do is if he see's an invalid ID, or a possible duplicated ID,is go to the system manager tools and completely disable that radio and render it into a paper weight. I have the ability to monitor my system for illegal radios, and with the stroke of a key, I can disable or enable any radio on my system. If that radio happens to be out of range, or turned off, the system will wait until it attempts to affilliate and then *Bang*....dead radio
