Help programming..R/S Pro-197
AB4BF
EM93cs
Isn't that the way it goes? Good luck, Ernie, and a big hearty Thank You to Ronnie!!
Barry
erniewrenn
south carolina
Barry
I finally found the program cables. No body carries them anymore. Also the Pro 197 went up to $397. The GPR's are $425.
ernie
erniewrenn
south carolina
live feed
Barry
I have been working on the scanner and think it is ready for "live feed". Do I run cable from speaker out to audio in? I have down loaded the "scanner cast" software. Is there any special commands to start the broadcast and does Ronnie need to be advised?
Ronnie jump in here..... I think we are ready.... Now looking for another 197 for mobile app.
We will be broad casting North Augusta SC PD.
ernie
RonnieUSA
Rowan County,KY (Morehead)
Barry
ernie
I don't have to be advised of anything, I was just trying to give You a hand with your problem.
I see You seem to have it under control.
Go luck on your live feed.
RonnieUSA
Ronnie
I was not sure if someone on the board needed to be notified.
Check out our web site if ya'll are interested in jets /rockets/turbine vehicles: JATO -Jet and Turbine Owners- - Home
Ernie
I'm a nobody, I just try, and help where needed.
If I think I can help.
Well I'm not into jet engines, but if there is something to listen to on the scanner about them Yes.
erniewrenn
south carolina
turbines
The are a few calls when we forget to call the dispatch and advise them we are starting to crank up the jet vehicles..... They WILL dispatch fire trucks when by passers call in that a jet has crashed and is exploding.
Thanks for the help...
ernie
