I'll probably be keeping it as a backup, but not 100% sure yet. I'll let you know.
on further consideration, since i need another 330, or any scanner, like a hole in the head (dirt cheap bargins excluded of course), allow me to upsale it back to you:
-the 380-400mhz coverage gap is a consideration with the 125, and for some places critical(not for me tho), but the gap that is most distressing to me is 54-87mhz, which is partly why i went nuts buying BR330Ts for a while.
since they were going for $200 at the time, and 125's for about $125, the unique freq coverage advantages of the BR330T, higher number of channels you could store, the all important search and store/close call and store options etc were totally worth it for me.
I realize milair is generally not thought of including low-band FM but my first BR330T was for the sole purpose of experimenting, with the lowest cost scanner i could find (hence why the 436 wasn't considered at the time) , with 54-87mhz. there is lots of helo low-band FM activity in my area, and when doing operations, A2A and A2G, its most often low-band FM, and there were many times where I knew i was missing something RF-wise. It has now become clear, that in my particular area, it is just as likely that 50-87mhz, more specifically 60-76mhz, will be used as 30-50mhz is used.
So if I was you, I would def keep it just for the times where helo traffic is heavy. But if I were you, and I were to disregard my advice, I, being you, would offer it to me for $20.
that totally makes sense the 4th time you read it. promise.
