Anyone know the color codes, timeslot, talkgroup info fror Highland Park PD/FD dispatch on 453.150 and 453.600? It would be greatly appreciated, thank you.
I'm seeing Color Code 5, TGID 101 appears to be Dispatch, with 103 as a secondart. I've also seen TGID 68 come up a couple times in logging, but have no information on it.Anyone know the color codes, timeslot, talkgroup info fror Highland Park PD/FD dispatch on 453.150 and 453.600? It would be greatly appreciated, thank you.
Lindsay,Is this showing up as a capacity plus system?
Russel, I would note that 859.9375 is still being used for Fire dispatch.
I have the 436HP (two of them), as well as the base version, BCD536HP, a BCD325P2, and a Whistler TRX-1. Other DMR scanners include the Uniden BCD996P2, Whistler TRX-2, Whistler WS1080, WS1088, WS1095, and WS1098. For the Uniden scanners, DMR functionality requires a paid upgrade. For the Whistler scanners, the DMR upgrade is free. There are also threads in the Whistler and Radio Shack forums about modification procedures to get the Radio Shack Pro-668 and GRE PSR-800 to accept a DMR upgrade. That requires some gymnastics to make firmware for a different scanner work in one it was not intended for. I have not tried that, as I do not have either of those units.Gentlemen, apologize for my being behind, especially as this technology has surpassed me. I have been an avid listener in the Dallas are for about 20 years, and a frequent user of the vast information this site has to offer.
As noted, HP DPS has switched over to the MotoTrbo trunked system. It appears that University Park is not far behind (can't find the link to their city council discussion on this, but once I do, I will provide it). I also believe that SMU Police has switched to MotoTrbo.
Now for my question: (My experience is primarily monitoring Dallas FD to keep up with all of my old friends (CH-1) conventional - as I used to be a Dallas Firefighter, along with a few trunked systems here and there).
By purchasing one of the applicable scanners, such as the Uniden BCD436HP, and with the additional firmware upgrade, will I be able to listen to these systems, specifically HPDPS in voice mode? If that is possible, would it be a waste if they are encrypting their transmissions (have not heard if they are or not)?
Many thanks for the time/feedback/advice and/or general responses!
On a system, such as HP, that is not extremely busy, scanning the channels conventionally works most of the time. For busier systems, such as the Megahertz Technology system used by CareFlite, that would not be satisfactory. Far too many users on there. Does your TYT give you talkgroup information? Looks like one of your earlier posts indicated that you can enter them.Just so your're aware the TYT doesn't "track" either, I scan four "channels", each of the two frequencies, on both timeslots for a total of four. Then I have programmed for each of those "channels" to receive both of the known talkgroups. When I turn the radio to the Highland Park "zone" or "bank" on channel 1, it automatically starts to scan. I hear appox. 98% of the communications, sometimes I miss a response or so if it is short, but this is what you compromise using a cheaper radio. If I lived in HP and wanted a radio I could depend on for reliable monitoring capability of the system, I would be 100% happy.
SMU does have a Uhf license for MotoTRBO, WQCH938 (SOUTHERN METHODIST UNIVERSITY) FCC Callsign DetailsYeah I had one of the first TRX-1's that HRO in Plano had on the shelf. However after its poor receive on the analog side and being unable to show any of the info(CC/TS/TG) from my TYT MD-380 on simplex in DMR like the rep. stated it would at the Dayton Hamvention, it went back on a Monday after purchase on a Friday. Also CC0601, you mentioned your interest in monitoring UPPD and SMU PD, although I am somewhat new to the area University Park PD is currently on an 800mhz analog conventional repeater, and SMU's Licenses for PD are on 800mhz as well. I scan UPPD and the two SMU freqs. on an old analog scanner, and have not heard any activity on the SMU PD freqs either analog or any digital noise indicating a switch of voice mode.
On the Dallas County side, there's a tendency for each jurisdiction to keep their own system, so that they have 'control', instead of working together so that they could communicate more easily in times of emergency. Contrast that to Tarrant County, where almost all the cities, as well as county, are on FWRRS.So the TYT MD-380 only operates from 400-480mhz(on the UHF version, they have a VHF version as well) which makes it useless for UPPD and SMU PD if they hold their current frequencies and just do a mode switch. I was quite surprised that the "Park Cities" public service forces radios were in different bands and modes. Where I've lived in W. Chicagoland, and Cleveland,OH the neighboring suburban communities stick together communications wise.
You're right, it does not specify what they may actually move to. Unless they move to DMR, along with Highland park, then your guess is as good as anyone else's.Thanks for all of the input.
Yes, I agree - hard to understand why HP / UP / SMU would not be on the same system and just utilize separate talkgroups.
My reference to UP possibly switching over was from their capital improvement plan. Appears it may happen sometime in 2018 (see PDF p28-29 in file link below)...although it does not specifically mention MotoTRBO.
Link: https://www.uptexas.org/uptexas/media/upTexas/uploads/Finance/FY15-CIP-Book.pdf
While looking at CAPRAD for 700MHz frequency information related to the Midlothian system being discussed in another thread, I noticed that Highland Park has requested five 700MHz frequencies. That may be where University Park, in conjunction with Highland Park & SMU, intends to move.Thanks for all of the input.
