Is the Hillsborough EDACS still on the air? I am not finding any control channels active or there seems to be no traffic but its still in the database so I'm assuming its still in use.
Unless they have moved off of it, the HillsboroughIs the Hillsborough EDACS still on the air? I am not finding any control channels active or there seems to be no traffic but its still in the database so I'm assuming its still in use.
Sounds like you're only listening via the east site #2. The even tacs are only on the west site #1.I'm using SDRTrunk and monitoring Hillsborough County P25, but I seem to missing all of the "even" Fire tac channels? I get Tac 1, Tac 3, and Tac 5 no problem. But even when I hear calls dispatched referencing Tac 2, 4, or 6 I'm not getting them...
Am I missing something simple? I monitor a lot of systems, and I've never seen a condition like this.
You're correct... I am not able to pick up the west tower where I am... Need to resolve that! I was not aware that some tacs were only one specific sites.Sounds like you're only listening via the east site #2. The even tacs are only on the west site #1.
Same situation as HCSO if that matters to you. All of the west side district talkgroups (D1 and D3) are only on the west site. Tampa PD and FD are also only on the west site. System users do not automatically roam like you'd expect in a multi-site system as most talkgroups are programmed to only operate off one site or the other. Even talkgroups like Countywide or HCFR Dispatch are programmed twice in separate zones, once for the east site, and again for the west. I don't know why they designed it like that.You're correct... I am not able to pick up the west tower where I am... Need to resolve that! I was not aware that some tacs were only one specific sites.
Tampa FD moved onto the P25? Last time I monitored they were still on the EDACS.Same situation as HCSO if that matters to you. All of the west side district talkgroups (D1 and D3) are only on the west site. Tampa PD and FD are also only on the west site. System users do not automatically roam like you'd expect in a multi-site system as most talkgroups are programmed to only operate off one site or the other. Even talkgroups like Countywide or HCFR Dispatch are programmed twice in separate zones, once for the east site, and again for the west. I don't know why they designed it like that.
They've been on the P25 system for a couple of years now.Tampa FD moved onto the P25? Last time I monitored they were still on the EDACS.
I'm running SDRs with SDRtrunk and not seeing any issues. Loud and clear.Is anyone having any issues listening to HCSO? It seems like its harder for my scanner to actually pick stuff up. Before I was able to hear everything on dispatch, now it just goes quiet for some time and then I hear something out of the blue. I'm not losing signal either. Just curious if its just a me problem or if others are having similar problems.
Is your scanner database up to date with the frequencies and sites?Is anyone having any issues listening to HCSO? It seems like its harder for my scanner to actually pick stuff up. Before I was able to hear everything on dispatch, now it just goes quiet for some time and then I hear something out of the blue. I'm not losing signal either. Just curious if its just a me problem or if others are having similar problems.
All info for Site 001 is correct.Request:
can someone check / verify via DSD+ or SDRTrunk this control channel & site data?
Hillsborough County (P25) Trunking System, Tampa, Florida
Hillsborough County (P25) Trunking System Profilewww.radioreference.com
I can confirm they are fully encrypted now as of tonightDid Temple Terrace PD go encrypted? That sucks if they did.
