I am just a rookie when it comes to police scanners. I have recently bought a uniden home patrol one. The symptom I have been having is that when I program a certain station into my scanner it never does anything. I have never downloaded sentenial, there for I have not updated the scanner since I have had it (9 months). Could this be the issue?
Hi gant
Welcome to RadioReference.
The fact that you've never installed Sentinel, and so have not updated the scanner, could indeed be a large part of the 'problem'. The database in the scanner as shipped will be a number of months out of date to begin with. And if, during the past nine months, you haven't updated it, that's putting the information even farther out of date.
The location you have entered as your location is in Michigan. While you haven't stated what you're trying to monitor, many agencies in your state, including state, counties, and cities, are on the statewide
MPSCS trunked system. For that system, many of the sites have gone through the
rebanding process in the last few months (see
this thread). That means that the transmit sites have new and different frequencies assigned from those used, say, this time last year, and different than what's in the "old" data in you non-updated Home Patrol.
First things first. Download and install the latest version of Sentinel; that can be found
here. Then, once you've installed Sentinel, update the master database, then download that to the scanner. You can download the manual
here, or from this
page.
Once you have both Sentinel and your HP-1 updated to the latest database, then try creating a new Favorites list based on your location. You can also use the "Easier to Read Manual", which may help as well.
Easier to Read HomePatrol Scanner Manual
