Hot band tonight!
Forts
Ontario, Canada
Super band opening here in the London area tonight... pulling in all sorts of stuff it seems. Lots of MotoTRBO Connect Plus control channels on UHF.
VA3QRM
EN82mh
good tropo this AM......0 last night
Funny, nothing 6/3011 PM here in Windsor; Forts, but now 07:00 7/1/11 Chatham and Wallaceburg Fleetnet towers booming in with 396T and Comet SMA 3 'handheld' antenna.All 162 mhz weather broadcasts very loud with "heterodynes" also band enhancement noted on 440 mhz ham band as well.
Forts
Ontario, Canada
Looks like the opening is to the east now... instead of the usual south western openings we get. I'm getting some stuff from over KW way quite clearly.
Muxlow
Super Secret
Middlesex County
I was getting one of the windsor LTR systems super clear on my CDM1550LS+ from london
Forts
Ontario, Canada
Another strong opening tonight. I'm getting MPSCS and Ohio MARCS on my Pro106 just sitting in my living room. Wonder what I might be able to pull in with my yagi.
Forts
Ontario, Canada
Thanks... haven't seen that one before. I am picking up a crazy amount of stuff only using a rubber duck on my Pro-106 (listening to the Ford Windsor TRS now) and a TON of MotoTRBO stuff from Detroit/Windsor.
VA3JWO
Madoc, Ontario
lucky for you guys...southeastern ontario pretty quiet tonight with a little bit of cb skip and a few things from rochester area
Forts
Ontario, Canada
Too much to listen to tonight... I had to gather all the troops! haha
uncleblackie
Nipissing District, Ontario
Nice shack pic.
Tonight I'm hearing lots of Fleetnet towers I don't usually pick up.
Why can't it always be this way! LOL!
Gonna see what the HF bands are doing.
Might get an opening on 10 and/or 6m
Forts
Ontario, Canada
Yeah no kidding... would be great if there was always this much to listen to.
EJB
20 + year membership
Downtown Hamilton
I'm not quite as succesful as you guys but I am getting Brantfords EDACS system clear enough, normally all the intermod and pagers and distance shut that out. I can barely hear Simcoe's fleetnet tower, but I wish I could snag something like Cedarwoods or Guelph Woodlawn from my 'radio room"
webstar22
RenfrewCountyScanner.com
Ontario, Canada
That map is cool. I just use the EC radar, the brighter the echos that don't move the better the conditions. They have also just died in the past hour or so.
Natchitoches
That is a very cool map... I love how it updates... Looks like a nice band has opened up from Windsor/Sarnia thru to London.
The map will get stale from time to time. Select one of the stations and check last update times for last refresh time. It is based on 144mhz band and may or may not be indicator of 450 or 800 Mhz but usually is.
Ground clutter on radar site is a good reference also. One that you guys have not mentioned is TV DX for an indicator. Before digital TV I would run the channels with antenna pointed various directions but now that requires a rescan so I keep up with some key stations different directions that are not normally received without K factor bending signal to me.
