How can I know the Address of my Pagers?
Lup1n
Hello, they gave me 2 pagers, a Motorola GoldLine and an Advisor, in neither of them can I see the Address, I would like to be able to send a message with my SDR equipment, but I don't see it anywhere, at a hacking convention there was a pager that had his address written and we were able to send a message
WhatsApp Image 2023-11-07 at 7.47.41 PM.jpegWhatsApp Image 2023-11-07 at 7.47.28 PM.jpeg
a417
if you want to hack, you need to learn how to research. Full stop.
It's more than just jumping on a message board and asking someone to handhold you. I'll be willing to bet with the information on the back of those devices, and the power of the Googler, you can figure out what you need.
GTR8000
NY/NJ Database Guy
BEE00
Aww, where's the fun in learning something on your own?!? Besides, our time is less valuable than others, obviously. Fear not, some hero will probably come along with a spoon, we have a few of those around here. 😂
MTS2000des
5B2_BEE00 Czar
SPOON FEED ME. SPOON FEED ME. Not.
This really isn't that hard if one has an old pager test set like a Ramsey APTS-3000. I remember when these were being tossed out about 15 years ago, they were practically free. Now you'll pay some coin for one:
Lup1n
si quieres hackear, necesitas aprender a investigar. Parada completa.
Es más que simplemente saltar en un tablero de mensajes y pedirle a alguien que te lleve. Estaré dispuesto a apostar con la información en la parte posterior de esos dispositivos, y el poder del Googler, puede averiguar lo que necesita.
Solo quiero intentar enviar un mensaje Solo quiero intentar enviar Solo quiero probar Solo quiero a Sólo WhoSólo Sí
I just want to play with the pagers to send a message, but I can't find information online that's why I turned here, maybe you had some guide on how I can find out the address,Or change it with a USB TTL
wtp
Port Charlotte FL
i do not know if the batter door has what you want or if it is just a serial number.
You need to first find the frequency of the pager, and then find the cap code. SDR+ and your SDR can help with both the frequency and cap code using a POCSAG plugin, assuming the message isn't encrypted. You can probably google the model number to help narrow down the band, VHF, UHF or 900 MHz. There is no easy way, it will take time and research on your part. Good luck!
WB5UOM
Ok I will bite, tell me how Sdr+ and a pocsag plugin gonna tell you the frequency and capcode of the pager..
if its not active on any system?
  • Like
Reactions: fog
WB5UOM
my money says a 20 year old advisor is not active on whats left of Skytell that was aquired by AMS... same for the other old clunker.
a417
The infrastructure likely isn't there, but the OP did mention they had SDR hardware - so they might just be trying to transmit locally and recieve it.
WB5UOM
I agreee, that last post was in response to RalieghGuy saying the OP never said they wernt active on a system.
Still waiting with baited breath to see how they intend to find the Capcode and other pertinent info needed to make it go off with only Sdr+ and a pocsag plugin...
Even knowing the CC isnt going to guarentee a readable message
Lup1n
Hello, as far as I saw it is just a serial number, the address is 7 digits as I saw
La
I have the frequency of the gold line, I don't see the frequency of the advisor, regarding the address, I can't find it for the goldline and I think I found it for the advisor but I'm not sure...
Exactly, it is not on any system, I want to do it locally only
Exactly, it's not on any system, I want to do everything locally, I have a hackrf one with the porta pack, it has POCSAG, but I need the frequency (in goldline I have it) and the 7-digit address (in advisor I think I have it), But in advisor I think I only have the address and I don't have the frequency, and in goldline I have the frequency but not the address
If it is not on a system my response does not apply in this case. The only way I know of finding the address (Cap code) of a pager not on a system is to get the programming software and look at what was programmed.
