BCD436HP/BCD536HP: How often to update database
ps249
Michigan
How often is it recommended to update the database on the homepatrol scanners? I know the database is updated every week but is it necessary to update your scanner every week?
omrail
Leduc Alberta
It is up to you. if you never use the full database then no need that I see. If the area(s) that your going to be have been updated and you use the full database scanning then when it is updated is all you need. I very rarely update mine as I have the area around me in a few favorite lists so I just up date them as there is something new
marksmith
Anne Arundel County, MD
This is what I would recommend, unless you have a new system coming on you are following or you are about to make a trip to an area you don't normally monitor.
Updating the database DOES NOT update your favorites lists, so it is really a matter of how you use the full database. I update it before I create any new favorites lists.
Sent from my LG-V410 using Tapatalk
ofd8001
Louisville, KY
+1 on Omrail
I typically update the full database just before an out of town trip. Every now and then I might get a new SD card because I get a wild hair about a new profile. As part of the new SD card preparation, I'll update the full database.
ShyFlyer
New Mexico
I update mine when I think of it which is typically once every two weeks.
I only scan what I have in Favorite Lists, but when I create those lists, I pull from the Sentinel DB.
stingray327
San Francisco, California bay area
So it does not automatically update FL? Then you have to go to the main database and append that info to your FL?
Voyager
Correct. The SW has no way of knowing which FLs you want updated and which you do not.
