Sentinel: How to change audio option in Sentinel?
threeofnine
mc48
Monroe County, NY
Digital Code Search would be correct if it is digital, if analog you would switch the left column to analog, or all for analog and digital search.
Looks like dispatch is digital but unknown on the others, I would set the dispatch to Digital Code Search and the others to all to find out what they are, then change as appropriate after that.
threeofnine
Thank you for this. I am either doing something wrong or my version of Sentinel is different. There are no site options and nothing in blue.
threeofnine
Thank you! I will try this and see if I can pick up anything and then make a note.
threeofnine
Success! I am able to receive. However, it is showing the NAC as 218. I can’t understand why I was never able to receive any transmissions before changing to “Search.”
RandyKuff
Lorain, Ohio
Your picture in post number 5... It's showing 000 for the NAC...
Did you click on it to select NAC 218 from the list?
threeofnine
The database uploaded at with NAC 218 by default. However, until today I was never able to pick up any transmissions. When I changed it to "search" I was suddenly able to receive transmissions. I don't understand how that is possible,
RandyKuff
Lorain, Ohio
So your saying the pict in post 5 was showing NAC 218 initially?
If not, change it...
All that is is an analog channel using P25 Digital Voice encoding...
Just like my local police...
RandyKuff
Lorain, Ohio
Yours should look like this...
It does load from the database that way... If thats not working I'm not sure why it does when Audio type is changed to search...
threeofnine
Yes, that is what I was confused about. I've tried to listen to this frequency for months on my WS1040, before I obtained an SDS100. Yesterday was the first time I have successfully received a transmission. Weird.
