aerialscan
- Joined
- Dec 28, 2019
- Messages
- 2
- Reaction score
- 0
Will appreciate some Three Stooges caveman comprehension level "slowly I turned step by step" instructions or link to YouTube video, if any exist.
How do I copy what was on the OEM SDS100 SD Card, that also had some local programming done to it by the seller, > to a new formatted 32gb card I formatted and am running in the radio now and > to other new 32gb cards I format later, so I have several spares?
My formatted 32gb card is set to scan zip code now and until I figure out how to work the radio, create and edit profiles. I'd like to run what's on that pre-programmed card without damaging the OEM card that seller programming is on.
I'd like to keep multiple spare backup cards, so the OEM card can be kept in a safe place without risking erasure or other damage.
I'm no tech guy, but I tried this below before and it didn't work.
How to Copy an SD Card to Another
I only have SanDisk 32gb cards to work with.
The SD Card Formatter and Sentinel are on the Windows 10 PC.
Later I'll have to figure out how to edit and create my profiles and lock out unwanted channels, using the software for the SDS100. If I can drag and drop files from this site, into the SDS100 and modify them, even better, once I get out of the hole of a zero pp balance to purchase a membership.
By chance, I was able to format a SanDisc 32gb SD Card to my SDS100, without receiving the dreaded Initialization errors.
Then I was getting USB low voltage error screens on the SDS100, using a USB socket multiplier connection to the laptop, until I placed the USB cord into the laptop directly to solve that issue.
Thanks for your time and any help
