How to FPP edit scan list on APX8000?
WA6PMW
WA6PMW
Does anyone have a quick tutorial of editing conventional scan list via FPP on a APX8000 ?
I am getting into it but I just can't figure out how it's supposed to work.
Or if it will work.
mikewazowski
Forums Manager
Oot and Aboot
FPP doesn't have anything to do with editing a scanlist.
You can press the scanlist edit button or select Program from you menu and then Scanlist. Both of these assume someone has set the Scanlist so it's user editable and they've assigned a button or menu item which allows you to edit the scan list.
WA6PMW
WA6PMW
Still not working. I'm new to the APX8000. Where do I set the scan list to be editable in the CPS?
It looks like that's what I'm missing.
K2NEC
NA
Radio Ergonomics Configuration > Controls > Menu Items
Add SCNL into "Selected"
GTR8000
NY/NJ Database Guy
BEE00
You can also access the scan list programming via a long-press of a button mapped to SCAN, or by setting a switch to Scan List Prgm. If you have a display radio, the easiest way is to add a soft key SCNL item, as @K2NEC noted.
You also need to set the Non-Priority Members field to Operator Select in each appropriate scan list, otherwise you won't be able to edit the list.
WA6PMW
WA6PMW
The operator select on the scan list is what I was missing.
Working great now.
Thank you...
