Since you got two conflicting responses, I'll chip in, here. Jerri is correct, you program this system as a Motorola Type II UHF system.
To determine the system type, you should ignore the "System Voice" line in the DB. Pay attention only to the "System Type" and the frequency set. If the System Type is P25, then program it as a P25 system. If it is "Motorola Type II..." then you always program it as a Motorola Type II, even if the System Voice says "P25 Exclusive".
