How to program Bell FleetNet Zone 2 for BCD325P2
Tim_Mcgee
Band Plan1:
141.0150, 143.9850, 15.0, 380
Band Plan2:
151.7300, 152.5100, 15.0, 579
Band Plan3:
154.3200, 156.2250, 15.0, 632
Thanks but when I do that, what do I do after it’s done.I tried that today and I couldn’t hear anything So I don’t know what I am doing wrong ?
I just want to make sure I have the right Band Plans
When I go to the site I do new site then Custom ? Then enter band plans ?
I am going to be doing it tomorrow, so I will tell you each step I do just so I know I will make it work out this time
ProScan
Software Provider
Ontario, Calif.
Thanks but what I do that what do I do after it’d done and I try that today and I couldn’t hear anything? So I don’t know what I am doing wrong ?
Did you program in the frequencies in the sites?
Did you program in the TGIDs in the groups? If you didn't then set the System to ID Search and see if you hear anything.
An advantage of using Freescan or my ProScan is that we can look at the programming for any mistakes.
Perhaps, take a look at some of the YouTube videos. Search for 'programming bcd325p2', or 'programming trunk system DMA scanners', etc.
I'm really sure that it will be so much easier to troubleshoot when using Freescan. When the database file is uploaded here then usually we can see the problem right away instead of taking a day or longer with manual programming.
What version of Windows are you using?
Common problems with the software not communicating with the scanner:
1. USB cable not connected or using a power only USB cable.
2. Scanner needs a power cycle.
3. Serial Port driver not installed or not working. Use the Win Device Manager to get more info on that.
Here are the very basic steps: I would still look over the Easier to Read manual and the YouTube videos.
1 Create a new MOT (Motorola) system
2. Set the system options
3. Create a new site
4. Set the site options
5. Enter in the frequencies in the new site created in step 3
6. Go to the band plan menu then choose Custom then enter in band plans 1 to 3
7 Do step 3 to 6 again for another site
8. Create a new group
9. Set the group options
10. Enter in the TGIDS in the new group created in step 8
11. Do step 8 to 10 again for another group
Tim_Mcgee
I am doing the site now so do I put all of the Frequencies in one site ? Or do I create sites for all of the different Frequencies and each site has the same Band Plans numbers
ProScan
Software Provider
Ontario, Calif.
Put just the frequencies assigned to that site.
The Ottawa (CARLSL) site has these frequencies assigned
141.405141.690141.870142.095c142.155142.245
142.335142.680142.830c142.890
Don't put frequencies from other sites in this site.
Tim_Mcgee
Thank you. Can I please have the Band Plan and Spacing, Offsets again, please.
ProScan
Software Provider
Ontario, Calif.
Thank you can I please have the Bands and spacing offsets again please
See post #22. Here's the shortcut.
Tim_Mcgee
How do I know what TG area to put in to the Groups ?
ProScan
Software Provider
Ontario, Calif.
In this system Bell FleetNet Ontario Provincial Government Zone 2 Trunking System, Southeast Zone, Ontario
Scroll down to Talkgroups. 1st group is:
Interagency/Common/Mutual Aid
DECHEXModeAlpha TagDescriptionTag
80001f40D2PC ENFEnforcement CommonInterop
96002580D2PC PPSPeterborough Police ServiceInterop
96162590D2PC BPSBrockville Police ServiceInterop
327688000A2PC SAFSoutheast Zone Public Safety CommonInterop
328008020A2PC AMBSoutheast Zone Ambulance CommonInterop
328168030A2PC POLSoutheast Zone Police Common
You don't need all the TGIDs like you do with frequencies in sites. You can pick and choose which TGID's you want to listen to. You can put TGID's from one group into another group.
Don't worry about the service tags on the far right side. I mean they can't be inputted in your scanner.
Tim_Mcgee
Thank you. Is there an OPP TG I can put in as well?
Search the webpage for 'OPP'
I see
OPP Combined (Regular Operations)
OPP Detachment (Detachment Special Events)
OPP Intelligence
and a couple more
Do I need to put in more sites for that or just need groups and is it possible to do Zone 1 as well ?
ProScan
Software Provider
Ontario, Calif.
I would just use the site/s near you for now. If you plan on traveling then later, put in other sites.
All the groups within the system are automatically linked to the site/s.
Zone 1 is another system. Do that one later. Just try to get Zone 2 system working first.
When it's time to program Zone 1, The Band Plans are the same as Zone 2.
Tim_Mcgee
Thank you it’s working great! I’m hearing lots of EMS calls I think there a an OPP traffic on Zone 1 so would that work in my area ?
ProScan
Software Provider
Ontario, Calif.
Thank you it’s working great! I’m hearing lots of EHS calls I think there a an OPP traffic on zone 1 so would that work in my area ?
Great to hear!!! If zone 1 system has a site near you then it should. Zone 1 is a different system, as you know, so the whole process of programming a system has to be repeated.
ProScan
Software Provider
Ontario, Calif.
Yes I will check around but if you can assist with that would be great
If you don't mind, just go through this thread. Start with the very basic steps in #24 and see if you can do it without assistance.
I'll be here if you run into a sna,g but try to do it.
