How well do these splitters work?
WayneH
Forums Veteran
Super Moderator
Your master site
Ever hear of birdies? Spurious signals generated by digital electronics? You need to isolate two or more receivers so they don't interfere with each other. The port isolation of a Drop Amp does this, weak signal or not.
So what about taking in to account the port-to-port isolation of the output ports for any standard CATV splitter, same thing. I think for the most part it's not much of a worry.
But back to the OP....
I run the Stridsburg 4-port with one port split with a BNC T. Since the radios off the T are dedicated to certain systems with strong enough signal I don't have to worry about the loss. So that's an alternative if you forego the worries of isolation.
hvscan
Hudson Valley, NY
Wirelessly posted (BlackBerry9530/5.0.0.328 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Just put an Electroline 2802 into service. So far, so good. I am pleased with the combined reception I am receiving. Time will tell for sure, as to whether this is a good substitute for a multi coupler for my use, but I do like it so far.
tonsoffun
Senior Moderator
Central Ontario
You will be very happy with the Electroline's:). I have two of them in service to feed the bearcats!
hvscan
Hudson Valley, NY
Thanks Tons...already scouting out a 2nd one. You can't beat the price.
jackj
NW Ohio
Isolation
Yes, there is some isolation using a cheap splitter. There will be around 6 - 7 db of port-to-port isolation. That isn't usually enough to eliminate interference generated by the other radio. There is another option, spend several hundred dollars on a 2-port directional coupler.
ronhl
Live Free or Die St.
I measured the loss of an SP-1300 splitter using a Agilent Network Analyzer, so all can see.
insertion loss (db)
Freq (mhz input - out A output B terminated into 50 ohms
30 -3.9
40 -3.9
50 -3.9
120 -3.8
140 -3.8
150 -3.8
160 -3.8
170 -3.9
200 -3.9
240 -4
300 -4.1
400 -4.4
450 -4.5
480 -4.6
512 -4.6
600 -4.9
700 -5.3
800 -5.7
850 -6.1
900 -6.2
950 -6.7
1000 -6.9
1100 -7.8
1200 -9
1300 -10
jackj
NW Ohio
The network analyzer should terminate both ports at whatever impedance is selected.
jackj
NW Ohio
My goodness N_jay, you caught me on that one. I completely missed the part where he stated that port B was terminated. You know, this part:
"Freq (mhz input - out A output B terminated into 50 ohms"
I wonder if ronhl could be talked into running that test again, this time from Port A to Port B with the input terminated. That should give the port to port isolation. In any case, thank you for taking the time to run the test. It kind of looks like the splitter might be a ferrite core transformer instead of resistors.
ronhl
sp-1300 out-out isolation input into 50 load
freq:
50 = -29.4db
150 = -24.5
220 = -21.5
400 = -17.8
450 = -17.5
700 = -17.5
850 = -18.8
1300 = -13.8
lmrtek
A 99 cent 2-way tv splitter would likely do equally well since most passs 5-1000mhz with 3.5db loss per port
A receiver multi-coupler with a broadband preamp ahead of it would be the optimum situation but
with only 2 scanners, you will likely not need that level.
prcguy
Look at the test data in a previous post, these splitters reach 4.5dB loss at 450MHz and 6dB loss at 850MHz, not so good.
prcguy
N
N_Jay
Guest
prcguy
If the third port was not terminated, the measurements are not reliable.
N
N_Jay
Guest
mY bRAIN fART!
Feel free to make derogatory statements about my ability to read.
zguy1243
Calhoun Georgia
I have both the Stridsberg 4 port and the Scientific Atlanta 4 port active drop amp. Would anyone be interested in a video comparing the two? There is a difference in the amps. I can say that in the 225-400Mhz range the Scientific Atlanta 4 port models are better performers than the Strigsberg 4 port active.
mrkelso
NNJ
I got this one coming in next week.
