I live in ws Michigan (49348) and am thinking of getting either a Hp2 or Bcd996pt. My ws 1040 seems to be doing ok for the most part but wanting to upgrade. Any input would be appreciated. Thx
I'm not in your state, so my comments are based on what I see in the database. Hopefully, somebody local to you will share their input.I live in ws Michigan (49348) and am thinking of getting either a Hp2 or Bcd996pt. My ws 1040 seems to be doing ok for the most part but wanting to upgrade. Any input would be appreciated. Thx
For the HP2, you can use HomePatrol Sentinel, free programming software provided by Uniden. For the 996P2 you can use FreeSCAN, also free software. FreeSCAN is fine for P25 Phase 1&2. If you upgrade the scanner to DMR or NXDN, you will require ARC-XT or ProScan (Paid software). As hiegtx mentioned, the Allegan County site is simulcast. If the 1040 works at your location, either scanner should be OK. However, both could be intermittent as you travel around the county. Do you have that problem with your 1040?I live in ws Michigan (49348) and am thinking of getting either a Hp2 or Bcd996pt.
If you are upgrading, spend the extra for an SDS series. They will work with the planned changes to MPSCS. (So you don't have to spend more money later.)I live in ws Michigan (49348) and am thinking of getting either a Hp2 or Bcd996pt. My ws 1040 seems to be doing ok for the most part but wanting to upgrade. Any input would be appreciated. Thx
