HP682 Firmware Issue
Buella
Thank you, @Muxlow
Unfortunately, I'm not seeing the same results on my end, it's possible the radio may already be bricked.
Here's what I attempted:
Installed the 3.1.20.006 updater
Connected the radio via the appropriate cable
Powered on the radio while holding the PTT and TK buttons (device successfully entered DL mode)
Launched the software and confirmed it was set to Auto Mode
Upon attempting the upgrade, received the error: "Upgrade Failed! Query radio user define data error!"
At this point, it seems likely that the unit may be beyond recovery. We may need to proceed with an RMA.
Unfortunate, but it is what it is.
Thanks - your a life saver after i panicked...lol
wsp44
I have had couple HM782's with earlier FW go into a boot loop when updating to V3.0.12.015, the radio takes the upgrade fine, just proceeds to do a continuous boot loop after. I didn't realize that they had V3.1.20.006 out, I currently have one that is stuck in the boot loop, I plan to update to latest to see if that solves the issue.
mario5211
Hello. I bought a programming tool, but I don't have CPS v3. Could someone share it with me?
Regards
a2s
Regards
What do you mean by "programming tool" if it's not CPS?
The link will be valid for 24 hours.
a2s
mario5211
Great, it finally works. I'll program 6 radios for my FIRE DEPT.
Thanks a lot.
I'll get to work.
Muxlow
Super Secret
Middlesex County
If you see the CPS area does not match that means its not a NA radio its a EU or AS version radio and needs to correct CPS for that region
Everyone should be upgrading to this version if your already on a V3 firmware
