HT1250 LS+ Frequency Question
RetsoldierPH
Concord, NC
I bought a Motorola HT1250 LS+ , it is programmed with 925.150 and 935.500. Can someone explain to me how this is possible ? I don’t understand how this frequency is programmed on a UHF low split radio. (I admit I am not very knowledgeable)
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Model number from the chassis AND from CPS read?
RetsoldierPH
Concord, NC
I’m confused. If you were able to read it with the cable you have, then a new cable will not change the band of the radio.
What does the tag on the back of the radio show? Model #?
I didn’t try to read it with CPS.
I was able to “close call” it with a scanner to identify the Freq. which it was programmed with already. The radio is at home, I’ll update with info when I get off work.
brndnstffrd
CT
That is indeed a UHF radio, so as posted above, what you were seeing was most likely a harmonic or overload-related image.
a417
Yep, that's an R split HT1250LS+ radio tag. The 7AN is a nice touch, you will have slightly expanded signalling options over base.
My guess is you were overloading the frequency counting device by being in the same room with it.
RetsoldierPH
Concord, NC
Can you explain 7AN, as I have 2AN radios as well. Not familiar with the difference
a417
The "7AN", as you may well know, is the last 3 of the model #. 7 is the (keypad) feature level (used to only be 5 or 6 on the portables - as per the original moto documentation, prior to many subsequent revisions), A was model revision level, and N was the model package identifier.
There are a great many threads on here regarding capabilities, and many of them show how the radios capabilities changed during it's lifespan and support by moto...to the point that the later official moto released hardware contradicted or wasn't possible according to their own literature. The 7AN HT1250LS+ that I have is 160 channel UHF + advanced signalling (QCII dec/enc + full MDC support + and some other stuff) that if you looked at the moto sales / support stuff - shouldn't exist together.
I'm not going to rehash all the stuff that happened prior to us getting them back from the factory like that, but the higher that 3rd to last numeric digit is - the more goodness is inside it.
Now that's a screenshot from one of the last DSMs released for that line, and it doesn't show 7.
RetsoldierPH
Concord, NC
Thank you, I have always enjoyed learning. I’m really enjoying learning in this Motorola world!
