HT1250 Programming Questions / Issues
rfergie121
I need some assistance with an HT1250 radio. This is on channels that have the ability to switch between Repeated / Talkaround (Direct) mode. When on repeated mode, the PTT Sidetone (PTT transmit tone) sounds like normal. When the radio is switched to direct, on any channel, it stops making any noise when keyed up. It worked fine before I started programming it. They are using the same MDC settings. I did not change much of anything. Any help would be great!
a417
"I didn't change much of anything"
Do you have codeplugs from before & after?
rfergie121
I do, but all I did was add a few channels. I didn’t change the way the radio was configured. At least not intentionally.
carlnphily
I Think The Reason Is Simple But Not Obvious. None Of My HT1250;'s Will Send MDC On Any Repeater Chanel
When I Use Talk Around. So No MDC = No Side Tone. At Least That My Experience. So For Every Repeater I Program:
1 A Simplex Channel ( IE Talk Around)
2 A Repeater Channel
3 A Reverse Split Channel
It Consumes More Channels This Way, But Get MDC To Transmit All 3 Ways
